another freshman question
5 replies to this topic
  • kc55555
Posted June 18, 2006 - 05:56 PM
I just checked the valves on y 06 450 with 5 miles on it, I am nervous so I need some advice. The two exhaust were at .20 mm. two intakes were at .12 mm and one at .10 mm. Should I worry or just ride? Sorry I am a baby!
  • clark4131
Posted June 18, 2006 - 07:14 PM
Ride it. You're still in the break-in phase and within operating tolerances so don't freak. Change the oil, ride, change the oil again, ride, then recheck the clearances around 200 miles and shim if necessary. After that, do it once a year...SC
  • Matty05
Posted June 19, 2006 - 03:16 AM
:excuseme: :bonk: :busted: :bonk: :p
  • Yamaster
Posted June 19, 2006 - 04:14 PM
I have over 1000 miles on my odometer and still dont need a valve adjustment. Although a few hundred of them is from sand riding (and that isnt very acurate, I dont go 50 miles in 30 minutes). It still fires up easily, so I'm not worried. Just gotta keep fresh oil in it.
  • Numskull
Posted June 19, 2006 - 05:17 PM
Why are you checking your valves after riding around the block?? You will probally never have to adjust them.
Mess with your suspension settings and tire pressure for awhile :excuseme:
  • Matty05
Posted June 19, 2006 - 05:20 PM
Mess with your suspension settings and tire pressure for awhile :bonk:
:busted: Too true! :excuseme:
