YZ450F 2006 Spark Plug Removal Help and Jetting
6 replies to this topic
  • mtscott
Posted June 17, 2006 - 04:30 PM
Hello, I just bought a YZ450F 2006 and need to re-jet the carb. I just
installed a FMF pipe and it is now bogging when pinning the gas. I
went to pull the plug wire off and there is not enough clearence to get it
out of the hole. The plug cap is hitting the frame. I have the spark
plug removal tool from yamaha, but just need to get the plug cover off.
The service manual does not give me this information.
Also, does anyone have information on how I should jet this bike? All the jetting is currently factory and the elevation here is 2500-4000 feet with a temperature of 80-100'F.
Any help you can give me will be greatly apreached!
Thanks much,
Mike :excuseme:
  • Wyatt
Posted June 17, 2006 - 05:09 PM
On the '06 you have to remove the motor from the frame to change the plug.
Not really......just wiggle that thing off. It will come off.
  • Ga426owner
Posted June 17, 2006 - 05:27 PM
Patience Grasshopper it will come out -
jet 48 pilot jet
165/170 MJ
  • barch88
Posted June 17, 2006 - 06:45 PM
Unplug the wire from the cap, then try it. I had same problem. My bike was popping on decel, I changed pilot to a 48, kept the 165 main. Your high elevation though, ask Burned what he thinks.
  • mtscott
Posted June 17, 2006 - 06:55 PM
Who is burned? I am new at this forum.
Thanks,
Mike
  • barch88
Posted June 17, 2006 - 07:03 PM
Burned is jetting expert for this forum:
http://www.thumperta...mber.php?u=5934
Posted June 17, 2006 - 07:08 PM
That's his old TT member name. Now he goes by Eddie Sisneros. Here's what he thinks:
http://www.thumperta...ad.php?t=316355
