stripped choke cable
12 replies to this topic
  • Muddin
Posted June 16, 2006 - 06:12 PM
Took carb out tonight to rejet and when putting choke cable back on noticed threads are pretty much gone. It does stay in the carb and seems to be working,but am wondering if it will hurt to ride till I can get a new cable. Do they make a cable that has a metal threaded end?
  • tirebiter
Posted June 16, 2006 - 07:04 PM
Mine did the same thing after countless removals.
What I did to keep it inplace was put teflon tape on the threads, thread it in till snug, then a dab of silicone over the area where the nut meets the carb.
Worked great for a few rides, then got tired of re-jetting that crappy POS carb & bought an Edelbrock.
NOTE: This site provided the above link, not I. If you have the "L" model, check with Barnums or Edelbrock itself.
  • Muddin
Posted June 17, 2006 - 07:17 AM
Well I geared up a small piece of hose to my vacume cleaner and made sure I cleaned out any plastic pieces from the choke hole and used Tirebiter's idea of the teflon tape. Seems to be holding, new cable should be here first of week. :excuseme: Thanks Tirebiter :bonk:
  • tirebiter
Posted June 17, 2006 - 04:09 PM
Your welcome! :excuseme:
  • scooter1100
Posted June 17, 2006 - 09:22 PM
I stripped mine once, btw the plastic cap for a trx350quad 86-92 have the same nut even though the plunger and springs are different. Also, I wouldn't use a metal one, or you'll be trying to replace the threads in the carb body instead of the nut.
  • Warp
Posted August 11, 2010 - 05:39 AM
Well I geared up a small piece of hose to my vacume cleaner and made sure I cleaned out any plastic pieces from the choke hole and used Tirebiter's idea of the teflon tape. Seems to be holding, new cable should be here first of week. :banana: Thanks Tirebiter :eek:
Do you have to replace the whole cable and was it much trouble to do it?
  • akarob
Posted August 11, 2010 - 05:51 AM
This thread is from 2006
  • XR650L_Dave
Posted August 11, 2010 - 07:46 AM
You can't replace just the nut, if that's what you're asking.
You do just have to get it to stay put in the hole, though, so a kludge fix usually works.
Dave
  • NOV8TR
Posted August 11, 2010 - 07:40 PM
Mine broke,,,
The Honda shop wanted about $80 for the OEM part
So,,, I glued together the plastic with super glue, and reverse engineered the part.
Had a local machine shop bang out the parts from aluminum hex stock (cost about $80)
And used JB Weld to fix the threaded part to the body.
No more problems!
  • XR650L_Dave
Posted August 12, 2010 - 04:50 AM
Mine broke,,,
No more problems!
So the end part (the slide valve) comes off the end of the cable?
That makes a fix much easier.
Dave
  • Kenzo
Posted August 12, 2010 - 07:01 AM
Dave
yeah Dave there's a small clip u remove and it comes off the carb-end of the cable...:banana:
...u can see the slot for the clip in the pics. :lol:
the problem is Honda does not sell the plastic nut as a seperate part... :lol:
...maybe one of the carb suppliers? :eek:
i sent my spare(after R carb swap) plastic nut to one of the guys who stripped his.
  • XR650L_Dave
Posted August 12, 2010 - 08:35 AM
Mine broke,,,
No more problems!
So the machine shop had a limitation and had to make the threaded part separate?
Dave
  • NOV8TR
Posted August 12, 2010 - 06:37 PM
No, the shop could have made it from a single billet of material.
I choose to make two separate pieces to reduce the cost, and eliminate the need for a thread relief cut at the base of the nut. A relief cut would have resulted in a reduced surface contact area on the threads in the carb body. The carb body (being a cast part) I assumed to be made of a softer and probably non-tempered aluminum alloy. I wanted all the thread contact area I could get to keep from messing up the threads in the carb body when tightening up the nut, and making the part this way allowed that to happen.
  • 17 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
Honda XR650L 2016
  • 0 reviews
  • Hot  60 replies
Honda XR650L 2017
  • 0 reviews
