adding oil on 06
4 replies to this topic
  • riderman329
Posted June 16, 2006 - 03:30 PM
how are you guys doing this, the manual is saying to take the base valve off, just to take the cap off?
is this correct?
or can you just add oil in throught the air blead hole?
Posted June 16, 2006 - 03:42 PM
Do we have to guess what we're adding oil to, or are you going to tell us?
  • riderman329
Posted June 16, 2006 - 03:58 PM
sorry i ment adding oil to the forks
  • matt116
Posted June 16, 2006 - 06:57 PM
I tried to add oil through the air bleed but it didn't work, when you take the forks apart you will see why, the air hole is tiny.
Unscrew the damper assembly from the forks then you can slide the outer tube down and add the oil.
  • riderman329
Posted June 17, 2006 - 05:18 PM
yep i ended up doing that last night, went throught the trail and error process!!
  • 0 replies
  • Hot  113 replies
  • Hot  38 replies
  • Hot  47 replies
