Coolant leak from water pump
2 replies to this topic
  • Frank_z28
Posted June 16, 2006 - 01:57 PM
I noticed today that the small hole in the water pump is spreading a little bit of coolant when i twist the throttle. Is that normal? :excuseme:
  • clark4131
Posted June 16, 2006 - 05:21 PM
It's time to replace the water pump shaft, impellor and seals. Easy job unless you're a sally-pink-panties, 2.5 wrench difficulty :excuseme:...SC
  • jerryls
Posted June 16, 2006 - 07:57 PM
Do a search for "water pump" in this forum and look for a post by Indy. He lists all the part numbers you'll need.
Jerry
