So I walked into the garage this morning and saw... (pics/need help)
15 replies to this topic
  • Jaycycle
Posted June 16, 2006 - 08:24 AM
:excuseme:
I wiped it off but its defiantly coming from here....(I think called the oil hose)
The last time I road was Wednesday and it started leaking (must have been) last night. Although now that I think of it when I was doing the regular maintenance yesterday and I was going over bolts and remembered tightening that one. (only like 1/4 turn, if that). If you have any idea's on why its leaking its appreciated. Well I wasn't going to go do my oil change till after next ride but I'm going to go do it now. Then Ill check back here with any ideas. Thanks
  • Pincushion
Posted June 16, 2006 - 08:41 AM
Have you ever noticed any leaking in the past? Have you tightened that bolt ever in the past?
First step:
Remove the oil line and take the crush washer to NAPA for a replacement. Should cost a quarter (if that...). Start with the easy fix.
  • Jaycycle
Posted June 16, 2006 - 08:54 AM
First step:
No I haven't seen any leaking in the past and I don't think I have tightened that bolt before (haven't had the bike to long). I'm just about done with draining the oil. Once I do ill take the line out and replace the washer. But whats NAPA? Thanks a bunch.
  • barch88
Posted June 16, 2006 - 09:17 AM
NAPA is just a auto parts store.
  • Jaycycle
Posted June 16, 2006 - 09:33 AM
Heres an update
So should I replace the bolt and the o ring (not sure what crush washer is)? Neither look bad. Thanks for the help guys.
Posted June 16, 2006 - 10:05 AM
There is no crush washer there, so stop hunting. It is very unlikely that the O-ring was causing your leak. There could be a crack at the joint between the fitting and the line, but that's also pretty unusual.
I think you should look for another source, probably a crankcase cover gasket that has slipped inward between bolts.
  • John407
Posted June 16, 2006 - 08:19 PM
gray you could be right but, my '03 leaked from there until I changed the o-ring for a slightly bigger new one.
  • jamiehughes
Posted June 16, 2006 - 08:36 PM
o rings,especially ones that don't have any cuts in them, don't just start leaking overnight, i would also believe that there is a grack on a joint or a gasket has slipped, if the o ring was the wrong size it would've leaked before, especially since the bolt wasn't loose. make sure that the bolt under the one you just took off isnt the one leaking, i would also get the bile off of the stand and make sure something underneath isn't cracked. oil can trickle and go a lot of different ways when running down on something.
  • FlynRyn
Posted June 16, 2006 - 09:25 PM
put it back together, wash it off and clean the whole area with contact cleaner,
spray athletes foot powder around the area thats appears to be leaking (be generous and spray a large area) run MC until the oil stain appears in the white powder. Fix source of leak.
  • FlynRyn
Posted June 16, 2006 - 09:28 PM
Oh and if I were to hazard a guess it looks like the case cover gskt is leaking but follow my suggestion to locate the source of the leak.
  • Jaycycle
Posted June 17, 2006 - 09:23 AM
Yeah thanks for the suggestions. Im going to put a bigger o-ring in and I ordered a new clutch cover gasket. The gasket was old and not in the best of shape. Hope it works.
  • BergArabia
Posted June 17, 2006 - 10:00 AM
O-rings might not start leaking overnight.
But that particular O-ring gets taken out and in everytime you change oil.
I keep a couple of those spare and replace with new as required they cost about 50cents here so probably less in US.
  • ridered55
Posted June 17, 2006 - 11:28 AM
"But whats NAPA? " :excuseme: I think I found the problem!! :bonk:
  • kid on a 426
Posted June 17, 2006 - 12:08 PM
Go home
  • Code
Posted June 17, 2006 - 07:05 PM
thanks for that tip... :bonk: :excuseme:
  • mxrayser
Posted June 26, 2006 - 02:12 AM
I like it, Its like the rolling a fat chick in flour theory
  • Hot  50 replies
  • 5 replies
  • On January 15, 2017
