Need Help
3 replies to this topic
  • OcoeeG
Posted June 14, 2006 - 05:14 PM
So I just had the pig in the shop to get the valves adjusted. They
were out pretty bad. Thought all was well, went for a ride today and
something is still not right. The first odd thing is the bike seems
to be louder, more engine noise than it used to. And it seems like
there is a ticking or knocking that I do not remember before. ALso,
it is shifting funny. Sometimes will not go all the way into 5th or
won't shift all the way into first. It still runs pretty good other
than the noise. Maybe a little loss of power but nothing huge. If
you can help please do. Thanks in advance.
  • mikekay
Posted June 14, 2006 - 06:38 PM
Obviously it can be many things...but after a valve adjust when it "really needed it"--
the bike should have noticably MORE power.
Also--the ticking "might" be the vavles.
I would start with the idea the valves are not correctly adjusted. Thats just where i would start.
  • Falls A Lot
Posted June 15, 2006 - 03:53 AM
I recommend searching here, reading the manual carefully, then rechecking the valve lash. To the uninitiated, it's easy to rotate the engine backwards when locating TDC-Compression, thereby activating the "kickback" feature of the decompression mechanism and get false readings when lashing the exhaust valves. Must rotate the crankshaft in normal engine direction ONLY when positioning the piston at TDC-Compression to perform the lash check.
Even if you are having someone else perform the work, get a hold of a manual and read up on each issue so that you can crosscheck their work and be well-informed.
I have no recommendations to offer regarding the shifting condition.
Good luck and have fun.
  • ghoti
Posted June 15, 2006 - 04:45 AM
I would also check the oil level.
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  141 replies
FCR40 Tuning Woes- XR600R by aTuWitty
  • Hot  37 replies
1993 XR600R rebuild by ove
  • Hot  41 replies
  • 3 replies
What was your path to Beta? by officialhopsof
Dirt Bike   Make / Model Specific   Beta
  • Hot  79 replies
