Where to buy rear sprocket XR650L
8 replies to this topic
  • TREADMARKS
Posted June 14, 2006 - 04:13 AM
Anyone try using a 42 tooth rear sprocket?
  • roadcam
Posted June 14, 2006 - 06:19 AM
I wouldn't run a 42 ... the 'L' will barely pull top gear as it is ... will go almost as fast in 4th as 5th, if you've noticed ... but, if you still want one, check the Thumpertalk Store, or RockyMountainMC ... :excuseme:
  • TREADMARKS
Posted June 14, 2006 - 07:53 AM
I think it will pull a 42 just fine in motard trim with 17" wheels, hot cam, 10.5 piston, pumper and an FMF PC4 full system. :excuseme:
I can't keep the front wheel down as it is with 14/48 gearing. :bonk:
  • ghoti
Posted June 14, 2006 - 08:48 AM
Why not go with a 15 front, you'll be able to keep the same chain length.
  • roostmonster
Posted June 14, 2006 - 09:11 AM
I'll second the RockyMountain M/C. Their Primary Drive sprockets are cheap and as far as aluminum sprockets go I think they are as good as the "higher priced" competition...
  • TREADMARKS
Posted June 14, 2006 - 10:51 AM
I tried my 15 front and would ya believe my freakin chain is too short for it, as my rear wheel won't go all the way forward with the oversize rear rotor and extended caliper bracket. :excuseme:
  • HappyCurmudgeon
Posted June 15, 2006 - 03:42 AM
damned if that isn't the most distracting avatar i have ever see...
:excuseme:
  • TREADMARKS
Posted June 15, 2006 - 05:48 AM
:excuseme:
+1 on the avatar
  • TREADMARKS
Posted June 23, 2006 - 05:28 AM
I installed the 42 from sprocket specialist last night and rode 30 miles of freeway this morning to test it out.
What a difference. The rpms dropped big time and the bike is much smoother, yet it still pulls great 1st and 2nd roll-on wheelies.
After doing the math, the 14/42 that I have now is the same as the factory 15/45 setup. Go figure.
Now if I can just fix the tank slap wobble at 90! :excuseme:
  • 4 replies
Washington
  • Hot  32 replies
  • 17 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 3 replies
