IMS Tank
3 replies to this topic
  • Alex_YZ450F
Posted June 14, 2006 - 01:42 AM
For the 06 owners that have the IMS 3.1 gas tank I have a couple of questions. How much wider than stock is the tank? Also, will the Works Connection Rad guards work with the tank?
  • TeamEndo
Posted June 14, 2006 - 03:50 PM
The IMS tank is only slightly wider than stock, I can't say whether it will work with rad braces though as I don't have mine yet. The tank does fill up every nook and cranny around and below the aluminum frame, almost like it was blow-molded around it!
  • Stevequest2000
Posted June 27, 2006 - 12:30 AM
I have the IMS tank setup with the WC radiator guards. Mine don't bulge much, but I had to trim a good bit of the plastic from the back of the shrouds. I installed them both at the same time so I'm not sure if the tank caused them to bulge noticeably, but I know the Rad guards did. I just had to get a sharp razor and keep slivering off plastic. Small price to pay for all the piece of mind.
  • Javelin
Posted June 27, 2006 - 07:14 AM
Here is a pic of the IMS installed from the back of the bike. I thought I had one prior to installing the tank to compare, but could not find it. The tank is not wider than stock, it is a little taller and hangs down lower.
  • 0 replies
  • Hot  38 replies
  • Hot  36 replies
  • Hot  30 replies
