'02 426 high rpm noise/ping
3 replies to this topic
  • marcmo0
Posted June 13, 2006 - 08:24 PM
I was out riding the other day on some trails.1st-3rd gear mostly. We came to a road portion of the ride and we hit some high speeds, wide open fifth gear for a bit. While on the road I noticed what sounded sort of like a pinging, but only in the lower end of the throttle range in the high gear. It wasn't an overbearing ping, but was definitely there. When I opened the throttle up, the noise either dissipated, or was muffled out by the increased "braaap". Anyone else experience this? I am normally in the woods and don't open it up like that, so am not sure if this is normal, or precursor to disaster.
  • jeeper33
Posted June 14, 2006 - 03:46 AM
What kind of fuel were you running? I notice that on my raptor, and my YZ that if i run low octane fuel my engine doesnt like it, and does make pinging and knocking sounds...you could try some high octane, or if the yz is tricked out try some mix with race fuel. just my two cents...otherwise, was it like a rod or a lifter sorta sound? (that a car makes?) perhaps valve clearance?
  • marcmo0
Posted June 14, 2006 - 08:15 AM
valve clearances are ok, and I was running some fresh super. 91 octane is the highest grade here in CO. My motor is stock.
Any ideas?
  • jeeper33
Posted June 14, 2006 - 09:55 AM
were you able to isolate what part of the engine the sound was coming from?
  • 10 replies
  • Hot  38 replies
  • 5 replies
  • Hot  30 replies
