Ktm fan on my 650
8 replies to this topic
  • thouk
Posted June 13, 2006 - 08:11 PM
Hey Y'all,
I have been working on this for a little bit. I was able to find out from one of the guys on advrider.com about the Ktm fan. It comes with a mounting plate and wiring with a thermoswitch. I looked at his pictures :
http://www.advrider....highlight=xr650
I have made my own mount for the fan. I also made a small piece to fit on the top of the radiator so that I can have the thermo switch on it also. I have the thicker Fluidyne radiators so the fit is tight but still possible. I hope this gives y'all a little incentive. Have fun riding, Tony
  • jamestoo
Posted June 14, 2006 - 02:03 AM
Any idea what model KTM fan that is? or even better a part number
  • Chas_M
Posted June 14, 2006 - 06:03 AM
OEM KTM fan - - Part# 590.35.041.044...about $95 retail. Available 'Online' to KTMTalk members at a 15% discount.
  • drtrider145
Posted June 14, 2006 - 07:12 PM
I have seen a thread where you can take a old computer cooling fan 5-15 bucks and make a simalar mount to put on you radiators, I think I've seen it on thumper talk , the guy even gives you pn's and a templet to trace your own mount, if I find it I will post a link
  • thouk
Posted June 14, 2006 - 07:39 PM
DRTRIDER,
I looked at doing that. I actually bought what I thought were two nice, as in high volume flow, fans. When I mounted them they did not move that much air. The KTM fan is a Spal fan. Their webiste is Spal-usa.com. The fan's description is in the fans/motorcycle atv section. It is the four inch fan. If you have the stock radiators you could use the 5 inch fan with a little overage but the Fluidyne radiators do not allow much room to place the fan. I am supposed to be receiving the Trailtech Vaypor speedo next week. I am going to fit the thermoswitch from the fan on the temp fitting for the speedo. Doing that will allow the fan to have a more accurate temp for it's operation. The Spal fan has a lot more flow then the computer fans. I just blew my head gasket last week doing the motorcycle safety course on my Pig. Too much slow speed stuff for the pig without the fan on it. Now I will be able to deal with traffic. I am going to wrap the header during the rebuild. Have fun riding, Tony
  • 4whlfun
Posted June 14, 2006 - 08:11 PM
Sorry I don't mean to change the post but where did you get that tail light license plate holder at. :excuseme:
  • wr450fyamaha
Posted June 14, 2006 - 08:14 PM
computer fans are weak....they move almost no air....just enough to circulate the air in a cpu every minute or so....so its like 2 cubic feet of air per minute........almost nothing....
  • cleonard
Posted June 14, 2006 - 08:31 PM
While I agree that your typical computer fan is wimpy, they move a lot more than 2 cfm. More like 50 or so. You can judge the power of the fan by the amount of juice it uses. Normal cheapo computer fans use around .1 amps. They are quiet. More powerful ones make a lot of noise. If you look at some of the surplus places you can find higher power ones. For example All Electronics has one that is the same size as a typical computer case fan, but draws .5 amps. These move more like 150 to 200 cfm. It only costs $3.75. Even if it gets fried by water, or whatever, it's less than four bucks to replace.
The "real" fans are much better. For near $100 they should be. They are more waterproof and move more air with much greater force. The current for those fans is more like 5 or 10 amps.
  • wr450fyamaha
Posted June 14, 2006 - 08:35 PM
Yeah, 2cmf was pretty low but i was making a point.....they dont move enough air to make it worth it....unless you get a really powerful one.
