CR500 starting tricks?
17 replies to this topic
  • SCCRF450
Posted June 13, 2006 - 11:01 AM
I know ever bike is a little differant. All models have a couple little tricks my YZ426 was differant then the yz250 and differant again from crf450r
I just picked up this CR500 ('92) runs good and will start fairly easy when I get it right but not sure what right is yet.
So whats the process? Crack the throttle/pump the throttle/ hold Wide Open, kick anywhere/find dtc. choke it etc....
I think the compression might be low, doesn't seem hard to kick like I was warned it would be.
Thanks
  • Pig_N_CR5hundy
Posted June 13, 2006 - 12:34 PM
I have started all of my CR500s the same way:
Fuel on
Choke on
5-8 slow kicks to get the fuel into the carb (or put the bike in 2nd gear, rock back and forth to get the fuel started)
find TDC
Kick
Starts every time
  • jbird710
Posted June 13, 2006 - 12:47 PM
Fuel on
Choke on
find TDC
Kick
Starts every time
Ditto. The '87 I have, you have to get TDC at the very top of the kick starter so it will get 2 combustion hits on the kick.
  • SC_Spode
Posted June 13, 2006 - 12:49 PM
Fuel on
Choke on
find TDC
Kick
Starts every time
Assuming it is a cold start:
The above works or another variation is to lean the bike over until it drools out the overflow tubes a bit to give a real rich condition in the cylinder.
No throttle.
Once you find TDC, bring the kickstarter back up and kick it all the way through until the lever bottoms, like you're trying to stomp a hole in the floor.
I was doing it this way when I was 14 and under 100 lbs, so it's definitely about technique and not brute strength! :excuseme:
  • Jaycycle
Posted June 13, 2006 - 01:04 PM
Whats TDC?
  • SCCRF450
Posted June 13, 2006 - 01:09 PM
thanks guys that is exactly what I was looking for :bonk: :excuseme:
  • gunner150
Posted June 13, 2006 - 01:12 PM
Whats TDC?
Top Dead Center
  • gunner150
Posted June 13, 2006 - 01:13 PM
thanks guys that is exactly what I was looking for :busted: :excuseme:
Mine starts 1st kick every time with SC spodes technique :bonk:
  • joman2055
Posted June 13, 2006 - 01:51 PM
my buddy had an 84 that he could never get started so wht he would do was lean it on its side and wait till fuel came out the carb vent. then give it a good kick and it would fire up. now he does the same thing with his kx250
  • Shawn_Mc
Posted June 13, 2006 - 03:18 PM
Mine is ported, the head has been milled off and all kinds of other stuff. I broke off 2 kickers before I learned this technique
Push the kicker till it stops...then just gently push it past the first bump, then raise it back up and kick it through that last bump. The flywheel will have enough energy to come around again and fire it for you.
The later model 500's had reliefs ground into the exhaust side to let some of the pressure it out.
  • SCCRF450
Posted June 13, 2006 - 03:32 PM
WOW thats sounds like a lot of compression. That thing must be fast
______________________________________________________________
If I do a compression test on this bad boy what shoud I expect to see?
  • kx_rider53
Posted June 13, 2006 - 03:36 PM
How do you find tdc?
  • jbird710
Posted June 13, 2006 - 03:53 PM
When you feel the compression come up as you're kicking the starter, it will suddenly fall off as the piston passes top dead center. It is something you have to practice a few times to figure out but is fairly obvious.
If you are setting timing or timing the cams on a four stroke, it's best to follow the manual's instructions. There's usually a mark on the flywheel that you line up with a mark on the case to find the precise tdc.
  • XR250rdr
Posted June 13, 2006 - 08:37 PM
No throttle.
I was doing it this way when I was 14 and under 100 lbs, so it's definitely about technique and not brute strength! :bonk:
Mine wont start without giving it some throttle.
:excuseme: Otherwise that technique or pig_n_cr5hundy's technique both work.
Worn reeds or a leaking crank seal will both raise hell in starting cold.
  • Knos_CR500
Posted June 14, 2006 - 12:46 AM
mine works the same as you guys but i give her a little throttle:D
just have to..... sounds so good but starts easyier since i rebuilt her
  • idahoexcr500
Posted June 14, 2006 - 04:23 AM
For the three CR500s I had what worked well for cold starting was turn on gas and choke, lean bike over till gas came out the carb overflow. Then get kick starter at the top of its stroke and kick hard. Worked very well, later models (starting in 1989 I believe) have a groove cut in the cylinder that helps with starting.
When hot just give it some throttle and kick.
  • jesusfreak
Posted June 14, 2006 - 04:06 PM
i hope you know hiw to start it now
  • SCCRF450
Posted June 14, 2006 - 04:15 PM
:excuseme: I know how.
Building an 02 cr250 into a trail bike with goodies by Honda05crf
Dirt Bike   Make / Model Specific   Honda   Honda 2-Stroke
  • Hot  45 replies
KP Racing Metering block - Dyno Results by CamP
  • Hot  314 replies
CR125 Sounds by MSFIT
  • 15 replies
250 2 stroke vs 125 2 stroke by pnitro4
  • Hot  63 replies
CR125 Carb Cleaning Help? by Will I Am
  • 6 replies
