Ti Powercore Question
7 replies to this topic
  • WGP
Posted June 13, 2006 - 08:41 AM
How do you clamp this muffler to the stock head pipe?
Its fits like a glove right over but the stock clamp is to big due to the stock muffler collar?
  • Matt B
Posted June 13, 2006 - 10:46 AM
i was told to use rtv silicone, but it blew out on the first ride, so im wondering the same thing if they make a clamp or not?
  • WGP
Posted June 13, 2006 - 10:52 AM
The directions said to use High temp RTV sealant, which sounds good, but I would assume that would be in addition to a solid clamp? Maybe Not?
  • WFO1
Posted June 13, 2006 - 01:48 PM
I just called FMF and they said it does not require a clamp! They told me just use high temp silicone seal. It's just a slip fit according to them.
  • 25year2stroker
Posted June 13, 2006 - 01:58 PM
I used permatex ultra copper,thin coating all around header about 2" in from end.Slide pipe on and tighten both mounting bolts,remove excess permatex let cure completely otherwise it will blow out as stated above.Worked fine no leaks I don't think any kind of clamp would work unless you cut slots in the end of the mid pipe to allow it to clamp down on header. :excuseme:
  • WGP
Posted June 13, 2006 - 02:13 PM
Mystery Solved, Thanks!!
Oh ya, The pipe was well worth the change :excuseme:
  • MountainMax
Posted June 13, 2006 - 05:17 PM
I have used that ultra copper high temp stuff on my snowmobiles, works great, if you let it dry 24 hours first........
  • YamahaWR450FMike
Posted June 14, 2006 - 02:04 AM
just used the high temp silicon for the fit and no problems here.
