Bent rear brake pedal
5 replies to this topic
  • drtbk4ever
Posted June 12, 2006 - 03:04 PM
Hey gang,
I did a search and it sounds like most just straighten the rear brake pedal when it gets tweaked.
So should I remove it and hammer on it, or stick it in a vise and bend it that way? Should I leave it on the bike and pull on it? Someone suggested heating it up using a blow torch, is that OK?
Thanks for all your expertise. I'm learning, slow but steady.
  • Matty05
Posted June 12, 2006 - 03:21 PM
Be very careful not to snap it. They cost a lot of money to replace!
How tweaked is it? I would leave it on the bike but taking it off is very easy.
  • drtbk4ever
Posted June 12, 2006 - 03:36 PM
It got jammed under the clutch cover so i had to loosen it to get the brake disengaged. Very little damage to the cover thank god. I read somewhere that JB weld is the stuff to carry to make repairs.
I am concerned that if I leave it on the bike and try to bend it back that I will damage the mounting point at the frame. Is that a realistic concern.
And thanks Matty, you have been very patient with all my questions.
  • Matty05
Posted June 12, 2006 - 03:52 PM
I have seen people get home using gaffer tape! JB weld is a lot more perminant!
You wont bend anything - maybe the allen bolt - but the leaver will snap before that! The problem with taking it off is that you might use too much force on it and snap it. Just pull on it if it only has to go a bit. Go easy on it too.
Anytime! :excuseme:
  • bg10459
Posted June 12, 2006 - 05:57 PM
If $20-30 is a lot, maybe, but they're often on ebay for that much. I'd remove it, too, rather than break anything else. It's easy enough.
  • Matty05
Posted June 13, 2006 - 05:46 AM
They are like $110 retail, or $70 here from TT store!
That is a fortune for a pedal. $20 is a bargain!
