Aftermarket air filters for XR's
27 replies to this topic
  • Blome
Posted June 15, 2006 - 06:51 AM
#21
Just read this on Scott Summers 10 tips for the XR600R:
"1. To increase intake airflow, Scott removes the airbox snorkel and uses an aftermarket air filter. Scott recommends not removing the backfire screen from the air filter cage because it changes the intake air velocity and causes the bike to have poor throttle response at low rpm."
I'm thinkin I might just change the twin air cage that I bought for the stock cage. Hopefully that helps. Anybody know if the twin air would even fit on the stock cage?
  • XR650L_Dave
Posted June 15, 2006 - 07:59 AM
#22
They have two different part numbers.
yes, but they prob. obsoleted the number when they discontinued the 600.
D
  • Blome
Posted June 15, 2006 - 08:36 AM
#23
D
Good call, I didn't think of that.
  • bigtooth
Posted June 15, 2006 - 09:42 AM
#24
I run the twin air cage and filter on my 600r. I dont know if its correct or not, but I have the plastic cage inside the filter and the seal between the inside of the airbox and the filter is made when the bracket puts pressure on the cage and the filter gets pressed between the cage and the lip on the inside of the air box. Always wondered if this was right or not, it looks like a good seal. Anyway the twinair cage is like 15 bucks, I have the part # somewhere if you want it.
  • Blome
Posted June 15, 2006 - 09:53 AM
#25
Do you have a bogging problem with that cage? I have the same plastic cage with no screen and I get a bad bog when I wick the throttle open no matter how rich I jet it. What jets and needle position are you running with that setup?
  • bigtooth
Posted June 15, 2006 - 10:06 AM
#26
I can kill it if I really blip it. But my K&N used to do that also, I guess there both high flow setups compared to stock. I have don't know what the carbs set up like. I really need to learn a thing or two about that. I don't know what any of the settings mean or how to adjust it. But if I had to guess I would say it the stock setup. :excuseme:
  • bigtooth
Posted June 15, 2006 - 10:07 AM
#27
.....maybe not, it came with the k&n on it, maybe the previouse owner new what he was doing and did some adjusting.
  • Blome
Posted June 15, 2006 - 04:23 PM
#28
Chances are that the bike was jetted properly if it is running good with an aftermarket filter and cage. So does anybody think that the reason for the bog is because I used the Twin air cage which has no backfire screen and basically no restrictions at all?
Washington
  • Hot  32 replies
  • 17 replies
  • 4 replies
  • 22 replies
  • Hot  29 replies
