Drive chain problem
8 replies to this topic
  • WFO1
Posted June 11, 2006 - 07:31 PM
Hi Guys, I just picked up my 06 WR 450. I had just ridden it stock for about an hour and noticed my chain had been grinding away at the aluminum rear section next to the chain. I know my chain was a little loose from new strectch, but to grind metal on the rear section? It didn't go all the way through, just some slight grinding. Is this common for the WR's?
I have the jet kit and FMF Ti Power Core comming soon. This thing runs like crap stock. I can't wait to de-smog it!
Great site, and store.... :applause:
  • andy666
Posted June 11, 2006 - 08:01 PM
I think they all do it i know mine did anyway.I made a little gaurd out of some teflon works great so far.
  • Matty05
Posted June 11, 2006 - 09:39 PM
Common problem. Just keep that chain adjusted correctly to minimize it.
  • odonnks
Posted June 12, 2006 - 02:06 AM
Have you done the Free Mods yet?
  • Summit
Posted June 12, 2006 - 05:24 AM
Mine did the same thing. I keep the chain a little tighter (45 mm) now and it seemed to cure the problem.
  • WFO1
Posted June 13, 2006 - 01:34 PM
Thanks guys. I may try and make some type of guard for the tail section and keep the chain adjusted! I am in the process of doing all of the free mods. I also bought the Yamaha smog elimination/jet kit and FMF Power Core pipe. I hope to get it done by this weekend! It's almost embarrasing riding this bike stock, theres no power!!!
This site rocks!!!!
  • 25year2stroker
Posted June 13, 2006 - 03:56 PM
Same here,problem solved :excuseme:
  • WFO1
Posted June 14, 2006 - 10:16 PM
OK it's jetted and de-smogged and Wow it hauls now..... I still haven't put the FMF pipe on yet and it still hauls. I did all the free mods,wire,cut the air box holes,bigger main(168) and Yamaha AIS/jet kit. It took me about three hours. What a difference. Now I need to go ridin!!!
  • Matty05
Posted June 15, 2006 - 03:06 AM
Put the pipe on, it is 10 minute job, but then you got to rejet again.
BTW, your chain will still streatch a bit more but it will stop after 2 - 3 good rides.
