going into neutral
7 replies to this topic
  • theclone
Posted June 11, 2006 - 06:45 PM
does anyone else with a 99 YZ400 think it's difficult to find neutral? Also it seems the bike likes to go in to neutral at the worst possible moment unless you give it a good kick between first and second. I was reading the KTM forums and people were saying their KTM's are like this, but it's just the way they are. So I started to wonder if the YZFs like this too, or is it just me? :applause:
  • stock510
Posted June 11, 2006 - 07:41 PM
Yeah my mates 99 yz400f is the same, unless you give it a good solid shift between first and second you always find nuetral. You always hearing him missing second. Other than that the bike is bulletproof.
  • ovrrdrive
Posted June 12, 2006 - 01:00 AM
I used to have trouble hitting neutral by mistake too on my '04 but after I adjusted the shift lever down a few teeth I haven't had that trouble once.
I have big feet and the lever was so high I had trouble getting all the way into gear.
I don't know if that's your problem, but it warrants paying attention to.
  • SureBlue
Posted June 12, 2006 - 04:40 PM
I see many riders coming from the track and stopping into pits, the starting desperately to find neutral when the engine is running. I never understood this. I just come in, shut off right away and then put into neutral - no problems. My bike finds neutral easy, but why should I let it idle and tease the clutch?
If finding neutral is hard, it usually helps to keep fresh oil in the engine. If you hit neutral when riding, it is a shifting error or a KTM.
  • ben_suhard
Posted June 12, 2006 - 05:21 PM
The main reason to do it while the engine is running, is because it takes less effort to see if it's in neutral, you just have to operate the clutch rather than pushing the bike back and forth. I keep the engine running.
  • barch88
Posted June 12, 2006 - 05:38 PM
I usually just get tired of finding netural on my 06 and just hold the clutch in 1st gear, shut the bike, then go into netural.
I got a quick question here...
Why is it harder to start the bike in gear (holding cluth in) then in netural? Does the TPS switch/wire have anything to do with this?
  • ben_suhard
Posted June 12, 2006 - 06:05 PM
I thought it was just because the clutch still grabs a bit.
  • ovrrdrive
Posted June 12, 2006 - 06:47 PM
I think it's both, but it's not the TPS it's the light blue wire...
I dunno if that still applies to the '06's though...
And I never fooled with mine either. My bike starts too easy as it stands to bother with it.
  • Hot  47 replies
  • Hot  36 replies
  • 0 replies
