GTYR products for WR4
Hey guys, just wanna enquire, is it possible to mount the following items onto my WR?
GYTR Clutch Basket
GYTR Clutch Inner Hub
GYTR Clutch Pressure Plate
GYTR Clutch Cover
GYTR Flywheel - YZ450F
If so, which year does it goes well with?
The flywheel won't fit. That is for the YZ, and only for the YZ. They are smaller since the WR has a big stator.
The other clutch parts (which are Hinson!) will fit.
The stock clutch is fine, I would only change if you are planning a BIG power upgrade such as a big bore kit, but even then, it is up to the task.
