*** Need Advice Please ***
5 replies to this topic
  • josephsixecho
Posted June 07, 2006 - 06:32 PM
:applause: I want to turn my 05 YZ450F into a woods machine. I ride tight single tracks and the 4 speed gearing sucks :D . Any help would be greatful.
  • SureBlue
Posted June 07, 2006 - 07:09 PM
1. you can put a 5-speed WR transmission in it, see sticky
http://www.thumperta...ad.php?t=315799
2. gear it to 13 tooth front -52 tooth rear
3. put a GYTR offroad flywheel on it
http://www.yamaha-mo...5/0/detail.aspx
4. you may need stronger GYTR or Hinson clutch components
http://www.yamaha-mo...375/2005/1.aspx (basket, hub, pressure plate and clutch kit)
or
http://www.hinsonrac...rig_model_id=79
5. you can also put a Rekluse auto clutch in it
http://www.rekluse.c...index.cfm?CID=8
Start with 2 and 3, and you may already be happy with it.
Then you may need other accessories like barkbusters and a steering stabilizer, but they are needed for every bike and as per your likings.
And welcome to the forum.
  • mxrayser
Posted June 08, 2006 - 01:59 AM
I put mini bike bars on mine, easier in the tight stuff, and overall more comfortable, and flywheel weights would help too!
  • Ga426owner
Posted June 08, 2006 - 05:09 AM
You are not going to like my advice.....sell it and buy a KTM. They are the woods bike leader handsdown....by the time to get the blue 450 ready for the woods $ wise, you could have bought a KTM. I would buy a the 300 if it was me...and keep the yami for the tracks :applause:
Posted June 08, 2006 - 07:54 AM
I have to more or less agree. The YZ450 is a pretty single purpose bike, although I take mine pretty much everywhere. The 4 best things you could do would be:
> install the WR450 trans
> use a flywheel 8 ounces or more heavier than stock
> install a Rekluse auto clutch
> stop using so many asterisks
But once you get done with that, you will have a bike that may suit you, but will be less a woods bike than a WR is, and also less a high performance MX bike than it once was.
KTM's are indeed very nice stuff, although I would chose a 525 and let them keep the 2-stroke, but they are expensive to either buy or fix. I think if I were choosing a purpose-built woods bike, I'd go with a WR450.
  • MotoGoalie
Posted June 08, 2006 - 09:43 AM
Doesn't it make you wish that Yamaha would revisit thier early 90s WR project and segment out the YZF into a EXC like bike and perhaps give the YZ250 2stroke a WR look too.
Talk about walking away from the other manufacturers.
Hell, they could sell the kits to be installed at a few reseller/dealer or by the customer himself.
  • Hot  50 replies
  • 10 replies
  • Hot  113 replies
  • 0 replies
