Frame & Rear shock absorber Too Hot
9 replies to this topic
  • spyder8850
Posted June 07, 2006 - 02:02 AM
Anyone having experience after a long ride, the frame (right side) and the rear shock absorber is too hot due to the exhaust pipe being mounted too close to them. Anyone uses anything here to reduce the heat? Does the heat cause any long term effect on the rear shock canister?
  • Matty05
Posted June 07, 2006 - 03:00 AM
The long term effect is that it destroys the oil and gas in your shock.
It is normal for the frame to heat up. The exhaust system is bolted to it.
  • gregwr450f
Posted June 07, 2006 - 03:35 AM
Put some heat tape around the pipe and use some fibre washers where it bolts to the frame
  • spyder8850
Posted June 07, 2006 - 04:56 AM
That is exactly what I was thinking too...
I try to get some heat tape and fibre washers to fix them up...
Thanks guys!
  • creeky
Posted June 07, 2006 - 05:46 AM
A heat deflector can be made from aluminum that fits between the shock and the pipe. Make it with a tab so that the exhaust pipe bolt can hold it on. My wife remains mystified as to the disappearance of her aluminum baking pans.
  • TooFast
Posted June 07, 2006 - 07:31 AM
FYI - the shock will get hot by itself, especially when riding rough ground and it's stroking a lot. Some can get too hot to hold your hand on. I'd bet exhaust heat is the lessor of the two by a large marign. Just my .02
  • spyder8850
Posted June 07, 2006 - 07:34 AM
Do you have pic of it, if your don't mind?!
  • spyder8850
Posted June 07, 2006 - 07:35 AM
Make sense :prof:
Don't you always get HOT when being stroked!? :D :applause:
  • Matty05
Posted June 07, 2006 - 04:01 PM
First of all, you shouldn't cook with Aluminum.
Second of all, what were you doing in the kitchen???
  • Matty05
Posted June 07, 2006 - 04:02 PM
There could be other problems like frothy oil. It makes the shock heat up and very harsh.
