Bar height
15 replies to this topic
  • JayJayUK
Posted June 05, 2006 - 03:13 AM
Hi Guys, Im 6' 3" tall and am finding the standign position on my new ('05) WR450F uncomfortable especially on the wrists, I believe they need to be higher so have ordered a 'Renthal RC HIGH ' replacement bars. Has anyone else done this mod if so do any control cables etc need changing also?
  • Matty05
Posted June 05, 2006 - 03:20 AM
It all fits mate, don't worry about it.
I run Protaper fatbars with adapters that raise the bars a fair way over stock. No problems!
  • beakr
Posted June 05, 2006 - 05:33 AM
I'm running the Renthal Fatbar RC high bend on my '04, along with the adapters that give another 3/4" or so in height. (I'm also 6'3). Although I still have to bend over some when standing, it is much better than the stock bars. If the bars were much taller, they would feel like ape-hangers on a Harley when sitting. No mods or longer cables needed.
  • Team_Oatmeal_Pie
Posted June 05, 2006 - 02:27 PM
There are some pretty inexpensive bar risers out there, that work with the standard 7/8 bars and the stock triple clamps. I run a Thumper Racing 1.5" risers, these move the bars up and forward, I have them on my 2000WR400 and 2004WR450 and 1" riser on 1993 XR600. All with Renthal Jimmy Button High Bends. This makes standing very comfortable. I can ride with out wasting all my energy trying to hang on while crouched over.
The only thing I had to do to accomodate the mod was roll the throttle tube over, so the cables are under the bar instead of over, cut the grip off and re-glue a new grip on so it is in the right position. The rest of the cables have plenty of slack.
I thought the cables might catch on something, as the are under the handlebar, but its never happened once in over 6 years.
  • nitronaf
Posted June 05, 2006 - 08:59 PM
running pro taper pastrana fmx bend with fat bar adapters that add a bit of height.
6'2" barely gotta bend over
  • Kmorris
Posted June 06, 2006 - 02:10 PM
T_O_Pie, This is exactly what I've been looking for. Did you order the YZ units for I've not seen where they are offered for WR's?
Thanks,
  • Kmorris
Posted June 06, 2006 - 02:19 PM
I guess I should have asked a more general question. My '05 is new and I've got to stop buying new parts! :D
My next stop was going to be trees with extended clamps but I couldn't justify trashing brand new perfectly good parts.
The 1.5 " risers seem just the ticket. (6'3")
I'm also thinking about just cutting and welding the stock pegs - with a plate to drop about 1/2 inch.
I have a bunch of catalogs but haven't seen risers and could only imagine what they would look like. Where might I find a pair?
The Thumper Raciing site doesn't seem to offer them online - :applause:
  • Matty05
Posted June 06, 2006 - 05:01 PM
Be careful, the more higher the risers are, the more back your bars become.
I run Protaper Windham's for the height and they have less pull back too. I run them pushed forward a bit to combat what the adapters pulled the bars back.
This is why adjustable clamps are awesome.
  • Darth Wader
Posted June 06, 2006 - 05:14 PM
6'3" here and I'm running with Tusk risers ($20 @ Rockymountain) that add 1.5" and swapped the stock renthal bars for some Mini Hi-Bends. They add another 1.1" and have very little pullback. I have them rolled forward a tad and all cables fit fine. Actually, they are less tight than when I had the Renthals with the risers - the Mini bars are 1.5" narrower. Couple all that with some Powerpegz in the lowboy position and I can stand without crouching at all if I chose to. Makes for a very comfortable "attack" position also. Made a huge difference in riding by being able to stand without being over the front tire. :applause:
  • markvfr
Posted June 07, 2006 - 05:55 AM
I agree with nitronaf. After a lot of research I also went with that combo and I'm the envy of a lot of my riding friends. They give you the highest height increase (maybe except the Ramirez mounts), don't need to re-route any cables, not as wide (good for singletrack) as the CR/RM bends and extremely comfortable. I'm 6'2 and can stand straight up. Best upgrade on my bike by far.
Be careful about lowering footpegs... its a nasty way to lose a toe or break your foot on some stumps. I don't know where you ride but around my place there is a bunch of trails with stumps all along the trail that are just below the standard peg height.
Good luck.
:applause:
  • Kmorris
Posted June 07, 2006 - 10:47 AM
Thanks all who replied to my question. Looks like I'll have a new project soon.
:applause:
  • Matty05
Posted June 07, 2006 - 03:55 PM
They only lower less than 1/2"
If you were fat or didn't have suspension set up, the bike would sag more than 1/2"......................
  • TARFELE
Posted June 07, 2006 - 05:14 PM
go to barrisersersonline.com
I have them and I will never own another bike without them. It seems odd at first but they work great after the mental adjustment. The manufacturer is a good dude who will respond to an e-mail and answer any petty questions you have.
  • markvfr
Posted June 08, 2006 - 08:11 AM
Are you calling me fat? :D
Yeah, I don't know how much they lower the pegs but I've met people who lowered their pegs and ran into the stumps. Granted, their suspension might not have been setup correctly. I personally haven't hit any on that specific trail.
:applause:
  • TARFELE
Posted June 08, 2006 - 02:12 PM
Good luck.
:applause:
That is funny, I just had a conversation with a Yamaha Engineer when he was out measuring the stumps in the area I ride. :D
  • ncmountainman
Posted June 08, 2006 - 02:41 PM
Are you calling me fat? :prof:
:D
moose has just come out with a set that sets back a 1/2" but not lower,i was intrigued and ordered a set as they have a raised center bar for pivoting(i'm coming off pivot pegs) i was finding my toes grabbing stuff with the p-pegs in the lowboy position. they work way better but i will have to buy new bars as my riding position has me bent over to meet the bars too much(gonna try the fatbar mini bend) the moose pegs are a whole new aspect of adjustability :applause:
