Water wetter
13 replies to this topic
  • foxomatica
Posted June 03, 2006 - 09:35 AM
Anyone running this product. Are you running it with regular coolant as well. What kind of ratio's. Thanks
Fox
  • TWILES
Posted June 03, 2006 - 11:48 AM
Everyone here has gone to just running Engine Ice.
  • 642MX
Posted June 03, 2006 - 04:40 PM
Ditto. I never had any luck with additives, just use the Engine Ice. :applause:
  • CISCO
Posted June 04, 2006 - 04:07 AM
Water wetter and distilled water 50/50 works awesome. I have had zero benefits running engine ice. :applause: The 50/50 watter wetter/water worked better for me.
  • black_n_blue_thumper
Posted June 04, 2006 - 09:26 AM
I had great results with Water Wetter in my WR. I cant remember for sure, but I am thinking I ran 85% water with the recommended Water Wetter (not much) and 15% coolant. It says on the bottle what percentages to use. I was boiling regularly before WW and never did boil the Water Wetter.
  • foxomatica
Posted June 04, 2006 - 10:18 AM
Thanks for the input
  • pjriss
Posted June 04, 2006 - 10:46 AM
Any problems with corrosion using that mix?
  • bg10459
Posted June 04, 2006 - 05:55 PM
50/50 is a strong mix, but anyway, water wetter is a corrosion preventative, too.
  • CISCO
Posted June 05, 2006 - 01:05 AM
50/50 is not strong if your other medium is WATER. Granted for a coolant additive it is, but not if you run straight water. No Ive had zero corrosion problems. Keep it fresh and it works well. Change it every 20-30 hours.
  • tmckeown
Posted June 05, 2006 - 06:17 AM
Hi,
You add 1 oz of water wetter to a 1 litre of battery water.
Timo Mc
  • BIGMatt
Posted June 05, 2006 - 06:29 AM
I run 70% distilled water, 15% Water Wetter, 15% Glycol antifreeze.
Change it once per year.
I run the same set up in most of my cars too.
Water Wetter works great! And is avalible at auto parts stores!
  • mtrablue
Posted June 05, 2006 - 06:44 AM
be careful here. follow the instructions on the bottle and do a little on line (not just TT) research. using more water wetter than recomended can reduce it's effectivness.
  • spencenaz
Posted June 05, 2006 - 06:29 PM
Interesting tests done by dirt rider magazine an a lot of these coolants and collant additives in the last month's issue. I'd read that before plopping down a lot of money on these so called wonder additives.
  • 2tall2tall
Posted June 07, 2006 - 09:46 AM
BEEN USING EVANS NPG COOLANT IN ALL MY BIKES AND RACE CARS FOR OVER 15 YEARS.
IT IS AWESOME!!! CALL THEM AT 1-888-990-COOL I THINK THEIR WEBSITE IS WWW.EVANSCOOLING.COM
