Big Bore ...
2 replies to this topic
  • BIGchiefKODIAK
Posted June 03, 2006 - 12:02 AM
Is it practical? What sort of gains do you receive all through low to high?, Dependable, Worth the money? Can you put a stroker on as well? I am just wondering what all you can do to the wr but keep it reliable and prolong its life. I was really thinking about the yz cam i do not want to do so much to my bike it destroys it. Any knowledgeable opinions are appreciated :applause:
  • Birdy426
Posted June 03, 2006 - 01:21 PM
I put a Luke's Racing Big Bore Kit (98 mm 13.5:1 Wiseco piston, 444CCs) in my 01, along with hot cams. I did the hot cams before the big bore kit, and it really made a difference...a little more down low, a boat load in the middle (with a bigger hit), and a lot more on top. Plus, it got to the rev limiter a whole lot quicker. When I went to the big bore kit, the revs slowed down a little, but the power boost was HUGE. So much off the bottom that first gear became useless till I went up a tooth on the counter shaft sprocket! Worth the money? As a stand alone mod just because, though I love the extra power, I'd have to say it's only worth the bank for a racer. If you have to refresh the piston and cylinder anyway (as I had to), then it really isn't much more money over the cost of stock parts, and damn right it's worth every penny!
  • MountainMax
Posted June 04, 2006 - 04:52 AM
I would love to see some HP and torque charts with a big bore installed so i can see were it makes more power and how much more...
