Glass Lens for 100w bulb
10 replies to this topic
  • Blome
Posted May 30, 2006 - 05:14 PM
Where do you guys buy the glass lens for an XR600? I want to run a 100w bulb on my bike, but the plastic lens won't work. I know that baja designs sells them, but they're totally out and won't be getting them anytime soon. So I need another source.
  • rmhrc630
Posted May 30, 2006 - 05:24 PM
Honda OEM - it was an optional part on the early 90s bikes.
I have one with the factory 55watt light
  • Blome
Posted May 30, 2006 - 07:23 PM
You got an extra? :applause: But seriously, do you? Or do you have the part number on that? I can't seem to get any info from my local shop they can't tell me if it's glass or plastic.
  • rmhrc630
hang tite I'll get one...
  • rmhrc630
Posted May 30, 2006 - 07:35 PM
OK just did some searching
It is part number 33120 MK2 671 for the 1988 -91/91 XR600.
Thats the complete unit with globe and lens and wires.
Bolts staright into the XR600R and the 650R shroud as well. (I know I did it with the 650R shroud)
http://i26.photobuck...132_3212_r1.jpg
Can you tell me if HOnda make an OEM 100watt globe?
  • TREADMARKS
Posted May 31, 2006 - 04:18 AM
A 100 watt bulb may be too much for your factory wiring. On my L, I had to run bigger wires and use a relay to get a 100/90 to work reliably. If your wiring is overloaded it will result is reduced bulb life and possible damage to your electric system.
So be careful. :applause:
  • XR_mad
Posted May 31, 2006 - 04:59 AM
the aussie xr has the glass lens
  • cleonard
Posted May 31, 2006 - 09:39 AM
You will need an upgraded stator to run a 100 watt bulb. The stock stator is only good for 80 watts or so. The stock stator will run a 55 to 65 watt bulb easily.
  • Blome
Posted May 31, 2006 - 05:02 PM
Dude, perfect! :applause: I'll definetly get back to you when I find out if they make 100w bulbs. As for the stator and the wiring, it's already rewound for dual output and the wiring is upgraded. I run 125w on an AC circuit for my headlight, which is controlled by a relay. Than I run a DC circuit for everthing else, which really isn't that much (ie. horn, LED signals, LED taillight and brake).
  • rmhrc630
Posted May 31, 2006 - 05:54 PM
hey dude I spoke with my electric guru down here and he said you def need uprated wiring to run a 100watts.
The stock wiring and specifically the switches are made for only up to about 55watt.
Seems like you have had your upgraded.
  • Blome
Posted June 01, 2006 - 08:51 AM
Just bought one with that part number and the damn thing cost me $62 (not including the 100w bulb), but I guess it beats waiting for 3 weeks until baja get their stock in. :applause:
  • 4 replies
  • Hot  29 replies
Honda XR650L 2017
  • 0 reviews
  • Hot  35 replies
