XR 650L - Electrical problems - Nothing with Key but will compression start.
Help. :applause:
I went riding yesterday and when I got back the Electrical wont work.I took it up the McKinney/ Rubicon trail from tahoe so it was pretty bumpy but I did not crash or anything. I actually did not get to far because of all the snow.
The bike will compression start and the lights come on etc but the electrical does nothing when I turn the key. I checked the battery connection and it is all good. Lights horn and everything work once started.
Before I go home from work today and take a look does anybody have any suggestions???
Stupid Hondas & their safety switches were a problem until I just removed them all. You have a clutch safety switch, a kickstand safety switch & a neutral safety switch. Probably some more I can't remember right now but I had a few similar problems getting it to start.
Simply bypass them & remove them & chuck them in the nearest dumpster! :applause:
Easiest way to temp. bypass ALL the safeties is to take both clutch-switch wires, and ground them both.
Top bypass everything, its not enough to just connect them together.
Its a pain to wade through the schem to see why this is, and I keep saying I'm going to produce a simplified schematic of the safty circuit. Just gotts sit down and do it...
Dave
Once started everything works.
I checked fuses yesterday.
Kickstand is bypassed. I dont kw about the clutch.
New Battery about a month ago.
I will check the nuetral and clutch bypass tonight.
Thanks,
