Wind turbulence with cut front fender?
9 replies to this topic
  • XR 650
Posted May 28, 2006 - 04:21 AM
I'm thinking of cutting my front fender. I was wondering how it will affect it going down the highway? I ride to work alot up the interstate.
Thanks
  • WayCrazy
Posted May 28, 2006 - 04:27 AM
Depends on where and how you cut it. But i wouldnt think it should be all that bad.
  • roadcam
Posted May 28, 2006 - 07:30 AM
it works fine, as in the photo, I trimmed about 5" off my front, and tapered the tip, drilled four large holes at rear for more airflow to cylinder ... :applause:
http://i15.photobuck...am/5262d86d.jpg
  • Dual_Dog
Posted May 28, 2006 - 07:36 AM
If it's the 650L, then cutting 3" - 5" off the front will help by reducing drag, plus it gets rid of that oversized duck bill that ends up flappin' in the breeze at high speeds. :D
While you're at it, drill/cut some air holes/vents at the back. Helps to channel air to the head of the XRL's air-cooled motor. Highly recommended if you've got an aftermarket tank.
Lot's of guys, including me, have done the trimming & venting with great results... :applause: Check out the TT Garage for photos of this mod done by more than a few XRL riders.
  • roadcam
Posted May 28, 2006 - 05:22 PM
yeah, holes like these: http://i15.photobuck...am/eaf4ff6c.jpg
:applause:
  • wheelnut46
Posted May 28, 2006 - 05:29 PM
I put a UFO fender for a XR400 on mine. I cut slots in the back similar to the ones on a DR650 fender. The XR400 fender fits perfectly and it looks way better than stock fender.
  • xr500_89
Posted May 28, 2006 - 05:32 PM
i got a ufo front fenger on mine and its already got monster slots cut in it
  • wr450fyamaha
Posted May 28, 2006 - 06:14 PM
I have seen fenders with ports in the back that you can open and close.....
  • XR 650
Posted May 29, 2006 - 03:57 AM
I cut 2 1/2" off yesterday. It took the droop look out of it. Looks great. Doesn't flop around as much at higher speeds.
I was worried about getting mud on the cylinder fins by cutting to big of holes?? I ride alot off-road (when not riding to work), so I cut 1/4" holes in the back of the fender. They aren't noticable, but should help some.
Thanks
  • Dual_Dog
Posted May 29, 2006 - 06:37 AM
You can also put hardware cloth (screen) over the holes to help keep the larger projectiles from pelting the head. I used 1/4" x 1/4" mesh & zip-tied it on the inside & rear of the fender over the (8) 7/8" holes I drilled in mine. These are hard to see in the photo in the "garage."
Other guys have riveted, bolted & strapped theirs on. Many different ways to achieve the same results. :applause:
