Acerbis 3.4 tank and Unabiker guards
8 replies to this topic
  • gdm
Posted May 27, 2006 - 04:38 PM
Is anyone running this combo.? I'm having trouble fitting the right side back guard mount. The one held in place by the tank mount bolt. The guard has a portion that is flared out and is hitting the tank. The left side has the portion flared in and fits fine. Plus it is an extremely tight fit. Also, how are you guys running the fuel line with the acerbis tank? Any suggestion or pictures appreciated.
  • clark4131
Posted May 27, 2006 - 07:36 PM
I drilled a second hole in the guard just behind the original hole that mounts between the frame and the tank. The tank rubs a tiny bit, but not enough to make a difference in over a year. I also replaced the crappy hoseline that comes with the tank with 1/4" Tygon. I then used a 5/16" brass fuel line "tee" instead of the plastic "Y". With the increase in size, I don't even need hoseclamps to hold the fuel line on the tee. It's NEVER come off and takes a lot of strength to pull it off when I remove the tank. I route the right side line between the head and the carb, pic included...SC
  • simon@vic
Posted May 27, 2006 - 10:42 PM
^looks good.
3.4g =?? L
  • ARin
Posted May 27, 2006 - 11:00 PM
ya, that is a no-nonsense set up...
i like it.
  • simon@vic
Posted May 27, 2006 - 11:22 PM
3.4 gallon [US, liquid] = 12.87 liter...........i wish it was 14L+ {3.8+ gal}.
i just cant justify paying that much for a 2L gain over my 10L stock 2004 tank .
does any one know of a 3.8g tank?
  • ARin
Posted May 27, 2006 - 11:51 PM
not that i know of...thats why i ordered that 6.6 gal acerbis tank. I figure i can fill it with as much or as little as i want...
  • Bleeds_Blue
Posted May 22, 2007 - 10:53 PM
I already have the Unabiker guards installed and just ordered the Acerbis 3.3tank. This will help, thanks Clark.
  • crooks420
Posted May 23, 2007 - 04:45 PM
Any issues with the IMS 3.1 gal tank and Works Connection rad. braces on an 05 WR450?
The guards I have, the tank is on the way.
  • 92_YZ_250
Posted May 23, 2007 - 06:00 PM
safari (aqualine) has the 4 gallon tank
site specs:
Yamaha WR250 & WR450
Litres: 15.5
Colours: Blue or Translucent
Fits: All 2003-on WR250s & 450s
Includes: Fuel cap with breather hose
Price: $349
http://www.sporttour...ne_safari2.html
Heres a pic i found on here a while ago of it fitted
