YZ Plastics for a WR
4 replies to this topic
  • Vengeancemaster73
Posted May 27, 2006 - 06:32 AM
My question is what year yz plastics do i need to fit my 02 wr426f. If possible i want the lattest year that can fit. Also Which yz seat and gas tank would fit the WR? Thanks for all your help! :ride:
  • Birdy426
Posted May 27, 2006 - 08:23 AM
You can fit all the way up to 04 YZ plastics, but to put the 03/04 stuff on is a bit of work and a lot of bank but better ergos. Do a search in the YZ forum and you'll find all the directions and tricks. The 00-02 stuff is the same for all years, and witht he exception of the front number plate, will bolt right on your WR. The front numvber plate takes a little bit of mod work. Again, do a search here inthe WR forum and you will find details. As far as the gas tank, stock, Clarke, and IMS all make 'em, and the shape is the same for a stock capacity. For a bigger tank, it's a matter of personal preference. Te Zp Ty tank has the best ergos, but the choke and hot start are a bitch to get to. The IMS is a little wider and caries the fuel a little higher. Any YZ seat will work, stock, CEET, Complete Seat, ect.
  • FTD
Posted May 27, 2006 - 08:39 AM
Check "My Garage." The plastics on my bike are YZ plastics. The bottom bolt on the radiator shrouds needed some spacers to fit but over all fit pretty well.
  • Vengeancemaster73
Posted May 28, 2006 - 07:29 AM
Ftd thats a nice bike but can i use a yz stock tank because i dont want that big of a tank. Thanks for everything! :applause:
  • FTD
Posted May 28, 2006 - 08:35 AM
Ftd thats a nice bike but can i use a yz stock tank because i dont want that big of a tank. Thanks for everything! :D
My tank is 3.4 gallons just like the stock tank. It is skinny at the top like the YZ tank and puts the gas weight lower for better balance. :applause:
