risers for 06 yz450f
10 replies to this topic
  • ranger520
Posted May 26, 2006 - 06:33 PM
Does anyone know where I can find some 10mm risers for stock clamps?
  • SureBlue
Posted May 26, 2006 - 06:48 PM
See if you can find the answer from here
http://www.thumperta...earchid=1514270
Some use washers, some GYTR clamps, there is even one TTer fabricating and selling 10 mm and 15 mm risers, could not find his name. Whatever you do, use longer bolts if you put 10 mm risers under stock clamps.
  • cowboyona426
Posted May 27, 2006 - 10:48 AM
Coop39 sells 10mm and 15mm risers, but the 15's don't work on the 450. The 10's work, but the studs on the clamps no longer reach the locking part of the nut. I have a set of his 10's and used blue locktite when I bolted it up, so far no problems. Replacing the studs is not an option unless you want to cut the old one off, then drill/tap for a new one to be put in... more work than it's worth IMO.
  • DPW
Posted May 27, 2006 - 06:24 PM
http://www.yamaha-mo...0/0/detail.aspx
  • SureBlue
Posted May 27, 2006 - 10:51 PM
I forgot the stock ones have no bolts like my protaper mounts had but fixed studs, so not worth replacing, true. A set of higher aftermarket clamps is the way to go if you need more than 10 mm rise.
  • Fastdaddy
Posted May 28, 2006 - 04:47 PM
I have a set of pro moto billet 10 mm up and 10mm forward for the 06. I am pricing a sub mount and scotts steering stabilizer will know on tuesday the 30th if im getting it. If the price is right on the new setup, Ill let you have my old riser for half of what I paid. If interested pm me.
Mike
  • nam6667
Posted May 07, 2007 - 06:36 PM
Mike
Rockymountainatv has what you want.
http://www.rockymountainatv.com/
  • nam6667
Posted May 07, 2007 - 06:38 PM
Rockymountainatv has what you need.
  • never59
Posted May 09, 2007 - 10:52 AM
your link is to the home page? what is it you are talking about?
  • 35yz450F
Posted May 09, 2007 - 11:31 AM
5mm Spacer #GYT-2S275-10-03 Yamaha Part in Tall Bar Mount Kit #GYT-2S275-10-03
Stack two.
  • xcape
Posted May 09, 2007 - 12:10 PM
The stud is not long enough for 2 spacers on the stock mounts?? I was thinking about pulling the stud and using a bolt.......
  • Hot  47 replies
  • 0 replies
