Tachometer on Wr450?
3 replies to this topic
  • MountainMax
Posted May 26, 2006 - 05:57 PM
Can you get a Tach for these bikes? anyone have one? I am so use to snowmobile racing and i need to know my rpm to make max power for shiftout and stuff, i know biking is different but i am so use to 2 smokes i find i can't tell the rpm's im at on this thumper....
  • ARin
Posted May 26, 2006 - 06:43 PM
trailtech vapor
  • nitronaf
Posted May 26, 2006 - 06:48 PM
trailtech vapor
not out yet, aside from them saying release in may :ride:
  • OringGroove
Posted May 27, 2006 - 05:56 AM
Check out the Yamaha hour counters the newer model has a tachometer in it! So you can adjust your idle!
You really don't need to know the amount of revs your bike is doing as you fly down a dirt track! The last thing you want to do is have a look at a speedo etc! You will end up busted upside down on the track! You only need a tacho to set the idle. once you know what it is you can just listen and set it by ear! Just ride more and know that there is always abit more left in the motor! these bikes truly have awseome motors!
