rebore
3 replies to this topic
  • millydog
Posted May 25, 2006 - 11:39 AM
just having my 87 xr600 rebored and new piston cylinder was standerd do i fit a standerd head gasket or thee oversize 100mm one any help cheers Gareth.
  • cleonard
Posted May 25, 2006 - 12:05 PM
Guess I don't understand the question. The stock bore is 97mm. If you put in a 100mm piston, then you need a 100mm gasket. Otherwise use a stock gasket.
  • millydog
Posted May 25, 2006 - 02:05 PM
sorry i should of said the cylinder is only slightly scored so i will get away with a 1mm rebore and over size piston at the most.cheers.
  • Border Patrol
Posted May 25, 2006 - 02:26 PM
Dude...what are talking about?
If you need to bore, you need to take an oversized piston and your cylinder to a machine shop. If you're going to run an OEM piston, you have two choices.
PISTON (OS 0.25) 205959-001 $92.44
PISTON (OS 0.50) 206274-001 $92.44
Honda XR650L 2016
  • 0 reviews
  • Hot  60 replies
Honda XR650L 2017
  • 0 reviews
  • 17 replies
  • Hot  35 replies
