xr 650l subframe removal
3 replies to this topic
  • elrontx
Posted May 23, 2006 - 04:42 AM
can i remove the subframe and leave the stock fender on?i took off the stock taillight. this might sound like a stupid question but im an idoit when it comes to working on bike thats why i ride the bfp :ride:
  • pigryder
Posted May 23, 2006 - 03:29 PM
you should be able to take it off cause I think its main reason for being there is to support the taillight assembly
  • wr450fyamaha
Posted May 23, 2006 - 06:01 PM
If i remember right, the fender has to come off also but I'm not 100% on that. It isnt a typical subframe by any means, you could probably modify it so that you could remove the subframe unit and take off some pounds.
  • FOUR STOKED
Posted May 23, 2006 - 06:59 PM
If you are referring to the bolt on under rear fender brace, I removed it with the original fender in tact, but put a small homemade aluminum brace across the under side between the two end rails. I used this in unison with the Acerbis taillight conversion and did not have a problem.
  • 3 replies
  • Hot  35 replies
  • Hot  60 replies
Honda XR650L 2016
  • 0 reviews
  • 9 replies
