Race gas needed for 06 wr450?
6 replies to this topic
  • tenyart
Posted May 22, 2006 - 06:12 PM
Hello everyone,
With 12:3 to 1 compression, do we need to run more than 93 octane fuel? When I lug my bike in too high of a gear I hear a rattle/ping noises, but it sounds like its coming from the trans sprocket/chain area. Could it be pre-ignition? The bike runs great otherwise, but I don't want to cause damage.
Thanks for your input.
Terry
  • 642MX
Posted May 22, 2006 - 06:15 PM
Premium fuel will be fine for a stock motor.
  • odonnks
Posted May 23, 2006 - 02:07 AM
93 is fine, you probably hearing chain drive chain slap. Very common with these.
Here is the most recent discussion with a few fix's suggested. DO NOT OVERTIGHTEN THE CHAIN, if it is you can crack the output shaft case when the rear suspension runs thru its travel.
A new bike may need its chain readjusted every ride.
  • tenyart
Posted May 23, 2006 - 12:35 PM
Thanks for the advice. This forum is very proffessional and helpful because of people like yourselves. I will check the chain slack tonight.
Terry
  • GOTWHEELS
Posted May 23, 2006 - 01:30 PM
I use race gas for sand riding only.
  • odonnks
Posted May 23, 2006 - 04:33 PM
I forgot the link earlier...sorry
Chain slap > http://www.thumperta...95&parentpage=2
  • YamahaWR450FMike
Posted May 23, 2006 - 11:32 PM
Hello everyone,
Terry
I run 91 in my 04 WR450 with absolutly no problems. Sounds like you have a lean jetting issue
