New motor is fantastic
9 replies to this topic
  • Wheels up
Posted May 22, 2006 - 05:16 AM
I just built a 2004 XR 650 L from the ground up.
10.25:1 Wiseco piston STD bore
Hotcam
Mikuni TM 38 flatslide
Yoshimura exhaust
Uni filter
Smog removed
Airbox opened up
Bridgestone ED-77,78 Gritty tires
15-45 gearing
IMS 4.0 gallon tank
Acerbis DHH headlight
Superbrace
XR's only skidplate
Well the list goes on and on but I must say that the bike works awsome.
The motor has alot more power from down low to the top end. It pulls alot harder than a stocker and has a ton of throttle response. I am going to break the motor in a little and then have it dynoed. :ride:
I think it has to be jetted. It has a TINY backfire when i shut the bike off. Also a little flatspot when the throttle is wicked.
Any ideas for jetting? Right now i have a 270 main and 27.5 pilot. I was thinking about a different air bleed.
  • Wheels up
Posted May 22, 2006 - 02:25 PM
Any help?
  • Dual_Dog
Posted May 22, 2006 - 07:37 PM
You might want to do a search & seek out goblin127 here on TT. He's runnin' a Mikuni flat slide on his L.
A little pop could mean a rich pilot circuit. Higher compression = higher octane. Try different brands of fuel as well. Just that slight change might make enough of a difference... :ride:
  • Wheels up
Posted May 23, 2006 - 01:40 PM
Hey goblin127 are you here man????
I have a 270 main and 27.5 pilot with a 2.0 air bleed in.
I will try a search and try new jets.
Thanks
  • wr450fyamaha
Posted May 23, 2006 - 06:02 PM
Got any pictures? She sounds like a beast.
  • zodran
Posted May 23, 2006 - 06:25 PM
Thanks
Are you sure that's not a 170 main? Unless mikuni changed their jet numbers, I'm still running the same 160 that came with the 41mm mikuni performance kit to replace the stock cv carb. I keep the needle in the bottom groove.
I may have to try a 170, hmm, it's easy enough to change! Is the tm38 a pumper?
  • Wheels up
Posted May 24, 2006 - 02:54 PM
Nope not a pumper. It has 270 stamped on it..... :ride:
  • Wheels up
Posted June 03, 2006 - 01:41 PM
I tried a 22.5 pilot and a 260 main also I removed the 2.0 air screw and it made a big difference in throttle response. The bike hauled alot harder on the first drive. Im Not sure if Mikuni changed numbers or not. These mains have a symbol plus the number. I have 240 - 280 mains and 17.5 - 30 pilot jets.
  • zodran
Posted June 09, 2006 - 10:16 PM
Sorry Man, I was completely out to lunch on the jet numbers. The 41mm mikuni I have came with a 260 main, I go to 250 for Moab @ 4K and up. A 250 main won't pull Imogene without blubbering, so 8k and up I use the 240.
Enjoy your new engine, mines ate about 10k of my buddy's dust at about the same state of tune as your's. My bike doesn't roll on wheelie like it used to in 3rd so it's probably time to freshen things up again. :applause:
  • Wheels up
Posted June 10, 2006 - 11:52 AM
Well now I have a 260 main and 22.5 pilot. There is NO air bleed. Seems to work good. Still backfires when I shut it off. Still a small flat spot or load up also.
My bike will roll on wheelie in 3rd everytime. It will flip over if ya don't lift.
  • 4 replies
Honda XR650L 2016
  • 0 reviews
  • Hot  35 replies
  • 22 replies
  • Hot  60 replies
