Has anyone replaced their petcock yet
6 replies to this topic
  • Ga426owner
Posted May 20, 2006 - 02:38 PM
Today on my 03 I noticed once I turned the gas flow on, the petcock was leaking. I disassembled and reassembled and it still seems to get moist with gas at the seam. What is the best way to rebuild these? It looks like there is a metal oring gasket that looks pretty worn - is it prefered to replace this or the entire petcock with new? :ride:
  • Fastest1
Posted May 20, 2006 - 04:01 PM
There is a rubber o ring in the rebuild kit.
Posted May 20, 2006 - 07:22 PM
They list pn 3AJ-24534-00-00, an O-ring called "petcock seal", and 3AJ-24523-00-00, "valve packing". There's also the tank seal, pn 4X8-24512-00-00. Otherwise, it's the whole thing.
  • kid on a 426
Posted May 20, 2006 - 08:09 PM
I'm thinking about switching over to a WR petcock so I can have a reserve. Do you guys think it will work?
  • Ga426owner
Posted May 21, 2006 - 06:47 AM
thanks Greyracer - I will try these 2 parts first or the entire assembly is 4DP-24500-00-00
  • Fastest1
Posted May 21, 2006 - 07:02 AM
The part seems to be pretty universal as my dealer actually had it in stock! Probably the same part on a quad. Mine was doing the same thing a month or two ago.
  • Butta
Posted May 23, 2006 - 07:12 AM
I had the same thing on my '98. I ended up replacing the whole petcock for like $15. It was worth it, as the rubber inside was trashed, and it wasn't shutting the fuel off when it should have been. On a side note, I used the WR one while I had the YZ one on order and it worked....it's not perfect, but it worked.
  • 9 replies
  • 0 replies
  • Hot  50 replies
  • Hot  36 replies
