Valve adjust
19 replies to this topic
  • nxridge
Posted May 20, 2006 - 06:36 AM
My 06' XRL is a few weeks old.
I have 700 miles on it now . The oil has been changed 3x's
and filter changed once so far.
When do you guys suggest i check/adjust the valves ?
everything sounds good and runs fine.
Thnx.
  • wr450fyamaha
Posted May 20, 2006 - 07:54 PM
now, it only takes a few minutes.
  • justicedone
Posted May 21, 2006 - 05:44 PM
Its more like 2 hours, than a few minutes...you do have to remove the seat and gas tank etc, before you can access the head.
I wouldnt worry until 1500mi.
then maybe every 3-4000mi intervals
  • wr450fyamaha
Posted May 22, 2006 - 06:22 PM
Yeah, but those hours pass by in the blink of an eye because you are havin so much fun. They say to do it at like 250, 1000, then every 3K I think.
  • nxridge
Posted May 23, 2006 - 02:38 AM
thanks , ill have to look into it this weekend.
  • DGA
Posted May 23, 2006 - 03:57 AM
It only takes 20 mins on my 650R
  • frankstr
Posted May 23, 2006 - 05:51 AM
I check mine every oil change, thats at 600 miles...... :ride:
  • nxridge
Posted May 23, 2006 - 06:55 PM
i don't have the manual , but adjusting valves is no prob for me.
Anyone know off hand what the clearance is supposed to be on a 06' 650L ?
:ride:
  • goblin127
Posted May 23, 2006 - 07:46 PM
:ride:
Intake is .004 ex..005
  • uncleroby
Posted May 24, 2006 - 01:38 PM
I have an XR650R, I checked valves at 29.000 kilometers the first time: NO NEED to adjust them....
:ride:
Uncleroby
  • Maniak
Posted May 24, 2006 - 02:43 PM
I did mine at 1000, took less than 30 minutes, and I do them every 1000 mi. I know its an over do, and they stay right on with very little adjustment, but its also a good way to get a heads up on premature wear, watch for one being way out.
  • nxridge
Posted May 24, 2006 - 04:34 PM
Thanks for the info guys.
I dont think every 1000 mile check is a bad idea either maniak.
  • adam574
Posted May 24, 2006 - 05:34 PM
do you guys think most new bikes always need an adjustment after the first 1000 or is it kind of some do and some don't.
  • uncleroby
Posted May 25, 2006 - 01:17 AM
I have been told to not "disturb" valves if they are OK!
So I did and after many kilometers with XRs and KTM LC4 I never had problems!
The less you touch mechanical part the better it is.
Of course you have to do what it is necessary.
  • goblin127
Posted May 25, 2006 - 05:59 AM
It's been that way for me. With my old 750F 16 valve I only had to change a shim once in the 25K that I had it though. Every thing else was diff.
  • nxridge
Posted May 25, 2006 - 04:00 PM
i just completed the first valve check/adjust.
they were almost perfect , just tightened the intakes a little.
They were just about perfect anyway.
Very easy job , hardest part is the seat and tank :ride:
I have now hit 1,000 miles. Is there any benefit to switching to synthetic at
this point ?
I change my oil regularly on everything i own.
  • meathead87
Posted May 29, 2006 - 12:18 PM
i have a 525sx and need to do my valves, how? any books or links out there???
  • wr450fyamaha
Posted May 29, 2006 - 05:54 PM
wrong forum bud.
  • MikeZ
Posted May 30, 2006 - 07:36 AM
Just did mine on my '02 XR last nite. First time, took about an hour with my daughter "helping".
Intakes were tight as were exhaust. No idea how many hours or miles on the bike, but it didn't seem as though the access covers were off before.
-Z
  • Dual_Dog
Posted May 30, 2006 - 10:30 AM
I have now hit 1,000 miles. Is there any benefit to switching to synthetic at this point ?
If you change your oil regularly and ride mostly street, probably not. Full-synth does allow extended intervals between oil changes, though.
I run full-synth 15W-50 (non-"EC") with excellent results. I don't have any verifiable proof, but by my "seat-of-the-pants-ometer" I think the motor runs cooler & shifts more smoothly.
  • 22 replies
  • 3 replies
Honda XR650L 2016
  • 0 reviews
  • 4 replies
Honda XR650L 2017
  • 0 reviews
