The Famous Grey Wire
9 replies to this topic
  • turbbo
Posted May 20, 2006 - 12:53 AM
Hi guys, I picked up a 2006 WR450F on May 5th. Coming from a 2004 DRZ400 I wanted more power and something lighter. I have only rode it once and you guys are not kidding, in stock form my DRZ had more power than this bike. Anyway, I started doing the mods to it as posted on this site. I'm still waiting on the AIS removal kit and YZ throttle stop. My dealer said it should be at my house this Mon. I did the air box mods and instead of removing the inner baffle, I removed the whole baffle itself. I can't believe it's not that loud at all. My question. I removed the grey wire out of the 6 pin connector, taped it with electrical tape and siliconed the hole. I made sure 3 times I had the right wire. I put everything back together, went to start it and nothing. The bike turned over 4-5 times with the electric start and my battery died. I charged the bat. and the starter would turn over strong 3-4 times but the bike would not start. If I left the charger hooked up to the battery it started right up. If I use the kick starter, the bike fires up with the first kick every time and runs good. Any one else experience this problem? Thanks in advance for your feedback. Rob.
  • ARin
Posted May 20, 2006 - 01:15 AM
reconnect that wire, and see if that caused your problem. If it fixes the problem, then you disconnected the wrong wire.
Failing that, sounds like you have a bad battery. Nothing else that i know of would produce those sort of symptoms.
  • odonnks
Posted May 20, 2006 - 02:36 AM
Also, until you get the bike richened up, it can be tough starting on the button. Mine was a bear. Rejetted after the mods and fires everytime right away, after one stroke of the throttle pull the choke hit the button and there she goes.
I'd be interestred in your comparason to your DRZ after the mods.
  • MountainMax
Posted May 20, 2006 - 05:49 AM
was the grey wire in one of the 6 pin connectors being in the middle of the connector? right up close to the CDI on the frame??
  • Old_Yeller
Posted May 20, 2006 - 05:51 AM
Sounds to me like it is either a bad battery or a bad battery connection.
Good luck!
Fred
  • OneToGo
Agreed, once you get your "pilot" ciruit sorted with the propper jets it should start easier. Bump up the idle to "fast tickover" as well - it feels high but helps start. Also, you can turn the idle speed screw up just for start if you dont want to add a fuel squirt by the AP. The WR seems to fire better on the kick somtimes.. I have occassionally had the same experience? A well charged battery and fresh plug aslo helps, Try the iridium next time. The manuals/book start procedure is worth reading again - it is quite specific for differnet temps. Having said all that, sounds like you battery is not so good :ride:
  • OneToGo
Posted May 20, 2006 - 06:04 AM
Hey guys - no confusion needed. There is only ONE grey wire... :ride:
  • ARin
Posted May 20, 2006 - 09:41 AM
BUT, some people are color blind.
  • turbbo
Posted May 20, 2006 - 02:01 PM
Thanks for the info everyone. I will definitely adjust the carb and see what happens.
  • rich1167
Posted May 20, 2006 - 02:10 PM
Make sure you are charging the battery properly and with the correct type of charger. Your manual is vary specific about this. You can damage your battery other wise. I had the same type of problems with mine until I hooked up a tender. After that no problems. Most come with a pigtail that can be installed so you don't need to remove the seat to hook it up.
