Coolant Compatibilty
3 replies to this topic
  • Geoffsta
Posted May 19, 2006 - 04:58 PM
What coolants are or arent compatable with the original coolant ?
I just want to top mine up without replacing the lot.
  • briter
Posted May 19, 2006 - 11:11 PM
I'm using the Prestone-brand antifreeze that states it is compatible with any and all brands. I've mixed it with the stock Yamaha antifreeze without any problems. Be aware that I doubt Engine Ice (Propylene Glycol) will mix with an Ethylene Glycol base antifreeze like Prestone and the rest of the popular brands.
  • OneToGo
Posted May 20, 2006 - 06:10 AM
The Manual says :ride: dont mix different types. If they are the same chemicals then OK IMO, otherwise best drain and refill with a readily available one.
BTW: I read where water wetter and distilled H2O provide the greatest cooling capacity. Glycol with corrosion inhibitors have obvious merrit as well...
  • minion
Posted May 20, 2006 - 07:19 AM
I've heard from a few guys now that corrosion inhibitors are useless in the WR motor, since the motor and radiators are aluminum. Which is why I believe Indy_WR450 is able to run Evans NPG-R in the bike without any problems. I may be wrong, but if the entire system is aluminum and rubber, I don't see any use of them either.
M.
