Noisy WR
1 reply to this topic
  • CLW04WR450
Posted May 19, 2006 - 01:52 PM
When I have the plug in the exhaust, my WR450 has a lot of buzzing noises around the top end. Are these naturally loud around the cam train, or should I worry about it?
  • SJMC_DON
Posted May 19, 2006 - 01:55 PM
Have your valve clearances checked or do it yourself....... routine maintenance on WR's. If you here clicking then they are likely loose which is better than tight but have it checked and adjusted as needed. :ride:
