XR600R Cylinder Compatability
2 replies to this topic
  • DSTerry
Posted May 19, 2006 - 12:14 PM
I was wondering if a 1996 XR600 cylinder could replace a 1989 cylinder. I looked up the part numbers and the 1989 cylinder is part# 12100-MN1-672, and the 1996 cylinder is part# 12100-MN1-680. The cylinder and head gaskets are the same. I imagine the only difference is that the 1989 is nikasil plated, and the 1996 is not.
Since my 1989 cylinder is a little out of spec, and it is nikasil, I was hoping I could use this 1996 cylinder. I have not purchased it yet, so I can't really compare side by side.
Any info would be very helpful.
Thanks.
  • XR6's_rule
Posted May 20, 2006 - 07:58 PM
Yes your right here, the cylinders have indentical specs except that the '91 on part has a steel liner rather than a nickelsil liner. I've used a '94 cylinder on an '88 bike and it fitted without any mods.
  • DSTerry
Posted May 20, 2006 - 08:06 PM
Thanks. I'll consider this 1996 cylinder as a replacement.
  • 22 replies
  • 17 replies
  • Hot  186 replies
  • 9 replies
  • Hot  60 replies
