Stripped frame oil bolt - re-tap SCARED
4 replies to this topic
  • Mighty_Whitey
Posted May 18, 2006 - 04:10 PM
My bro has an 2005 YZ450f and has a stripped out oil plug on the frame. The thing goes finger tight but with a little turn of a wrench it will spin to finger loose. :ride:
Here is the question at hand...what is the right way of fixing it? Does he re-tap to a bigger size? Or try some type of thread repair Helix???
Of course the biggest issue is metal shavings dropping into the frame while re-tapping...if that happens how do you flush the oil without running it through the motor.
Thanks for the help.
MW
  • xcape
Posted May 18, 2006 - 04:41 PM
helicoil look it up on the net/search
or this
http://www.timesert.com/index.html
  • 642MX
Posted May 18, 2006 - 05:04 PM
I would use a helicoil if the hole is messed up, but you may just need a new bolt. A bit of grease on a tap will keep most of the shavings from falling into the frame. :ride:
  • huskysmr450
Posted May 18, 2006 - 05:16 PM
Here is the drill. use a helicoil, drill slow, grease the tap and run some oil through it you will be just fine.
  • Mighty_Whitey
Posted May 19, 2006 - 09:43 PM
Thanks.
  • Hot  36 replies
  • 10 replies
  • Hot  50 replies
  • On January 15, 2017
