sag amount vs. No. of turns on ring nut?
4 replies to this topic
  • imported_Scott_H
Posted October 24, 2001 - 03:44 PM
I had no luck with my search on this topic even though I remember reading it maybe a year ago or so...
Does anybody have a rule of thumb on how many turns it takes on the spring pre-load ring nut that will give you about 5mm of race sag?
  • Mook
Posted October 24, 2001 - 04:07 PM
I don't know if it is the same for the WR250F, which is what I have. But one turn = 1.5mm so you would be about 3 1/3 turns.
better get confirmation from a big bore though.
2001 WR250F
1975 KZ900 - project bike
  • mcarp
Posted October 25, 2001 - 04:08 AM
I don't think 3.5 turns is right. That's the shock travel difference, not the sag difference (5.5" of shock travel=over 12" of suspension travel)
I've found that slight movements in the rings make a BIG difference here. Mark where you are with a crayon so we can guage how far you turned the rings. Try just 3 "knotches" first and measure...IMHO
  • Bryce_Senff
Posted October 25, 2001 - 11:51 AM
I would think that the number of turns of the ring nut and resulting sag would be dependent on the weight of rider and gear. What do I know though?...I work in a grocery store.
My .02
Good Luck,
Bryce Senff
WMRRA #201
Oh it's Good to Be Back on a Dirtbike!
  • BlueThunder
Posted October 25, 2001 - 12:16 PM
Gotta go with Bryce on this one...race sag will be determined by rider weight w/ gear...
free sag will be determined by how worked over the rear spring is(even fresh springs will have a slight variations if you throw them on a spring tester) way to determine these settings by # of turns unless you were consistent on the rest of the variables in the equation. Turn and measure is still the accurate way to set sag.
