Gearing Question
4 replies to this topic
  • Punisher660
Posted May 16, 2006 - 09:42 AM
I last rode 5 miles of hell and geared the front down one tooth for better crawling speeds.....I'm going to the dunes this weekend. Should I keep the 1 tooth smaller front sprocket or go back to stock? :ride:
Any opinions on which gearing is better in sand?
  • CJ06WR
Posted May 17, 2006 - 12:23 AM
I've got the same question. I want to put a paddle tire on my bike and hit the dunes in Glamis. What are the other So Cal dune riders doing? I mostly ride in the desert so the stock gearing works fine for me. Any input would be great...
  • jonova
Posted May 17, 2006 - 06:38 AM
I run a 14/48 in the dunes and it does just fine. But on the big hills like Olds and Pattent I would rather have a 14/52 so I can use 4th gear instead of 3rd.
Punisher660 - I would put the larger coutershaft sproket back on.
  • Punisher660
Posted May 17, 2006 - 07:57 AM
but doesn't the smaller sprocket up front have the same effect as going larger in the rear?
What is stock.....I thought it was 14 and I went down to a 13
It sounds like you preferred the lower gearing which is how it is geared now
I guess I will bring the other with me and change it out there if need be :ride:
  • Yamaster
Posted May 18, 2006 - 02:53 PM
For sand mountain, I run 13-49 with a ten-paddle and it does really good. I've even beat a few crf450's with my otherwise stock 05.
