XR70 oil change
17 replies to this topic
  • ajd187
Posted May 14, 2006 - 05:24 PM
I just took a quick look at the oil in our XR70 and it is due for a change.
Will using the 10W-30 I have sitting in the garage hurt anything or should I be using motorcycle oil? I use automotive oil in my quad because it has a CVT trans which doesn't need oil (belt drive). However I'm unsure about the bike since it's an auto clutch.
I searched on this topic but couldn't find it. I don't need a debate; a simple yes or no will work. :ride:
  • qwoke-q
Posted May 15, 2006 - 04:23 AM
The automotive oil should be fine. Although I would use 10W-40. That's what the manual says to use.
  • RedRockRider
Posted May 15, 2006 - 04:49 AM
I may be wrong but, The automotive oils have additional lubricants in them that may saturate your auto clutch, and inhibit the performance of the clutch. I would use the Honda GN410-40 oil to be safe. It is cheap, and is what is recommended.
TJ
  • jvxrz
Posted May 15, 2006 - 05:36 AM
Not long ago you could use auto oil without a problem, but with the addition of "friction modifiers" that is no long true.
The way to tell if an oil has them is to look at the SAE donut. If it has modifiers it will have "Energy Conserving" on the bottom outer half.
One inexpensive and easy to find oil that does not have them is Shell Rotella. It's formulated for diesel engines, and for some reason doesn't have the additives. Guys on the SVrider forum (SV650 Suzuki) swear buy it.
Personally, I run a synthetic cycle oil. It does cost significantly more, but for the amount a 50 or 70 uses it's next to nothing.
  • CRF100biker
Posted May 15, 2006 - 01:58 PM
I've been using it and noting's been going wrong with it. I say use it!
  • Racer
Posted May 15, 2006 - 04:28 PM
Check the API classification. If it says SF or SG you'll be OK to use it, but as qwoke said, 10W-40 is recommended for warmer temperatures.
  • five0addict
Posted May 15, 2006 - 05:21 PM
for the price of a quart, put the good stuff in. look for "use for wet clutches" or something similar
  • ajd187
Posted May 15, 2006 - 07:05 PM
I was just thinking that I would use what I had laying around. But I went and got the good stuff. Just changed it tonight.
  • jvxrz
Posted May 16, 2006 - 05:38 AM
Current auto oils lubricate engine parts just fine, but eventually the "friction modifiers" will build-up on clutch plates. Older auto oil was fine, I used it for years, but things have changed.
But for the amount we use (next to nothing), and what we spend on our bikes, why not use the correct/best oil available?
  • CRF100biker
Posted May 16, 2006 - 12:04 PM
I don't spend crap on my 70 or on my 100. Once I get a KX 100 I'll be using the good stuff. Personally I think all the crap that the manufacturers say you have to use is a load of bull. If it works just as good and costs less then why not? Maybe the reason my bike's clutch didn't take a shit is cuz I've barely ridden my 70.
  • jvxrz
Posted May 17, 2006 - 06:38 AM
OK, but which is it?
You will give your KX the "good stuff" but you said you don't think there is a difference. If it "...works just as good and costs less..." why bother using anything different in the new bike?
There is a difference, you just can't SEE it.
Personally, it obviously doesn't matter to me which oil you use, I'm just tossing out the fact that there is a difference between auto and cycle oils.
  • CRF100biker
Posted May 17, 2006 - 02:20 PM
Ah you got me there.
  • dirtbkr188
Posted May 17, 2006 - 02:35 PM
Cheap insurance for a long lasting motorcycle engine: Use Bel-Ray EXL 10W-40 motorcycle oil, petroleum-based. It is around $20.00 for a 4 Liter jug. The XR70 takes 600ml (or cc) after an oil change. That's 6 oil changes for 20 bucks, using an oil made specifically for motorcycles.
  • mx2007
Posted December 10, 2009 - 06:23 PM
hey when i change my oil in my 99 xr70 i noticed 2 drain bolts? what is the second one for? and the engine oil goes to the trans also? cus mine is sticking really bad and was gonna put some lucas trans fix in....but if theres no seperate fill for the trans what do i do?
  • Towlieee
Posted December 11, 2009 - 01:30 PM
I run automotive oil in all my bikes, even my sport bike with 36k miles and the stock clutch
Just don't run fully synthetic energy conserving and you shouldn't have any issues
  • Towlieee
Posted December 11, 2009 - 01:31 PM
It's sticking? Try adjusting the clutch before putting addatives in..
The other bolt that sticks out at an angle is the cam chain tensioner, don't remove that bolt
  • mx2007
Posted December 12, 2009 - 03:19 AM
really? it looks like a drain bolt lol, but yeah as far as the clutch i adjusted it just didnt ride it yet been raining here, and also before i adjusted it the lock nut was loose lol. also is any one running the maxima hi performance oil in theirs? thats what i use to put in my 05 crf250.
  • todthebod
Posted December 29, 2009 - 07:43 PM
I've been using regular wal-mart supertech 10w-40. Use in in my cr250 clutch going on for about 3 years with no problems.
Honda CRF70F 2011 by ThumperTalk
Honda CRF70F 2011
  • 2 reviews
  • Last review by CB rides
  • On December 01, 2015
Pit bike in the making... by the-new-kid
Dirt Bike   Special Interest Forums   Pit Bikes
  • 3 replies
Honda CRF50F 2015 by Bryan Bosch
Honda CRF50F 2015
  • Last review by Texas248
  • On February 19, 2015
Honda CRF50F 2012 by ThumperTalk
Honda CRF50F 2012
  • Last review by skooli
  • On June 08, 2014
crf 50 oversized carburetor by anger806
Dirt Bike   Make / Model Specific   Honda   XR/CRF 50/70/110
  • 5 replies
