Headlight Issues
4 replies to this topic
  • cjp1135
Posted May 14, 2006 - 07:03 AM
I Have An 02 650r And Am Not Happy With The Stock Headlight. Any Advice As To A Good Relatively Inexpensive Aftermarket Replacement, Dont Want To Make Any Stator Mods. Also Interested In An On/off Switch To Go With It
  • motomonte
Posted May 14, 2006 - 01:33 PM
check with acerbis,they sell for about 80 bucks and the twin beams look cool,same 55w bulb.
  • jamestoo
Posted May 14, 2006 - 02:07 PM
I went with a baja designs duel sport headlight it comes with a replacement glass lamp and turn signals horn on /off swithch battery and relay all the wiring including battery is hidden in the front plastic behind the light......its briliant! :banana: :busted: :smirk: :ride:
Well worth it and you can leave your stator alone!
  • Desertskyy
Posted May 15, 2006 - 08:48 AM
It depends on how much money you want to spend.
I bought a new bulb (A-3603) It is a 25wt/25wt dual filament bulb. I soldered the two contacts together at the base and called it good. It has the same socket base as the stocker. I used an XR/CRF 70 engine kill switch for the bar mounted headlight on/off switch as it is a toggle type. Switch off E-bay was $8.00 a pack of bulbs was $3.00 from my local dealer.
Good Luck
  • motochris
Posted May 15, 2006 - 10:50 AM
Replace the stock lense with a glass one from an XR400....get it from your Honda dealer. You'll need the glass lense, and the rubber boot, then buy a 55w H3 bulb for it. BIG difference in light quality and quanity. I also switched to an LED taillight to lighten the elec. load for the headlight.
  • 0 replies
  • 7 replies
  • Hot  35 replies
Honda XR650L 2017
  • 0 reviews
Fell Off Trailer by usafxr
  • Hot  43 replies
