Taller bars, do the cables reach?
10 replies to this topic
  • MindBlower
Posted May 13, 2006 - 08:05 PM
Say a CR high bend? :ride:
  • qadsan
Posted May 13, 2006 - 08:43 PM
Yes, all the cables will reach with the CR Highs and a taller tripleclamp, but you may have to route the cables a little differently. Years ago I used to run CR Highs and a BRP triple clamp that raised the bars on my 650R with the stock cables years ago, but I've since gone to a custom set of bars that are even taller and they require the use of longer custom cables.
  • MindBlower
Posted May 13, 2006 - 09:03 PM
is the taller triple needed for some reason? or just another way of getting height?
I have Renthals with I "think" the high CR bend on my 350, thinking about taking them since I'm selling it anyway.
  • qadsan
Posted May 13, 2006 - 09:35 PM
Not needed. I just did it for extra height and a bit more reach since the clamps I use put the bars a bit higher and farther forward.
  • Potts228
Posted May 14, 2006 - 10:21 AM
I run the "Windham" Pro Taper bar (about the same height as the CR high but slightly different bend from what I can tell by feel) and the Scotts sub mount upper clamp. I'm 6' and this put the bars in a very comfortable position. I did have to get longer throttle cables and I run the Precision Concepts cable guide for the clutch cable.
  • skyriver
Posted May 14, 2006 - 11:12 AM
I also have the Windham bend (less pull back than CR-HI) Pro Tapers and Pro Tapers riser/adapters. I have the Contour series though, not the EA-70 and the Contours are only 31.50" wide versus 32" of the EA-70. I'm at the outer limits of the cables. Didn't seem to notice an issue with the throttle, but I did set the clutch about 1/4" in farther... It's more comfortable now anyway. You can always cut the bars, but I like all 31.50" since I'm 6'4". Probably depends if you set them at 0 position or crank them forward. That's why I got the Windham bend.... less pull back. You have to get the XR better for standing. It sucks stock form.
  • XRsteve
Posted May 14, 2006 - 01:46 PM
Probably the only way to see if the cables are long enough is to try it. If they're too tight, try trimming the end of the bars a little bit. This worked great for me.
  • Kenaroo
Posted May 14, 2006 - 02:57 PM
Ok.. If needed... Who sells longer thottle cables. or is there a cross reference to another mc that will work?
  • 4Takt
Posted May 14, 2006 - 03:10 PM
I have the CR High bend Pro Tapers with risers/adapters as well. If you leave the bars uncut it will work, but barely. It puts the throttle cables at their limit, clutch is no probem.
Then I got an Edelbrock carb and it came with cables that are slightly longer than stock: perfect fit.
But id did work with stock cables, there just wasn't much slack if any and you have to rotate the throttle body for shortest distance.
4Takt
  • Potts228
Posted May 14, 2006 - 08:11 PM
I got my cables from Scotts. Don't remember the price though.
  • Desertskyy
Posted May 15, 2006 - 08:54 AM
I am running a BRP triple clamp set up with CR-Hi Pro tapers with no problems with my cables. You just have to be careful with the routing.
  • Hot  29 replies
  • Hot  60 replies
  • Hot  186 replies
  • Hot  35 replies
  • 4 replies
