New Pipe and Jetting = Slower...???
8 replies to this topic
  • ACMoodz
Posted May 12, 2006 - 05:59 AM
My 05 650L feels slower!!!!! I put an XRs Only ss header and muffler with the quiet insert and a dynojet kit and...de-snorkeled. Bottom end is a little better but it falls flat on the top end. Any suggestions?
  • goblin127
Posted May 12, 2006 - 06:33 AM
I run the same pipe minus the quiet core and have only gained on the top. May be larger main and you might want to see what it runs like with out the Q core. You will have to experiment. I ended up putting on the XRs only mikuni flat slide carb and this thing runs so much better its amazing.
  • scapegoat
Posted May 12, 2006 - 08:18 AM
Do a couple full throttle speed runs then pull the plug and check for color. Its probably to lean. When you start to roll on the throttle up near the top end and it starts to flatten let back off on the throttle slowly and see if it kinda starts to pull again. This is also a sign of to lean top end.
  • ghoti
Posted May 12, 2006 - 08:48 AM
Did you also change the air filter?
  • ACMoodz
Posted May 12, 2006 - 10:39 AM
Yes, I installed a unifilter. I am gonna go back to the facory needle and shim it and try a larger main (that would complete "Daves mods")
  • lrutt
Posted May 12, 2006 - 12:15 PM
Just change 1 thing at a time, not 2.
Go with the larger main first.
When tuning carbs, never adjust 2 variables at once. You will never know which is taking care of the problem.
  • ACMoodz
Posted May 12, 2006 - 03:00 PM
I have the Dynojet main in it now. I have several main jets. Will regular jets work with a dynojet needle?
  • goblin127
Posted May 12, 2006 - 07:51 PM
They worked for me but in the end I went back to the factory needle shimmed.
  • martinfan30
Posted May 12, 2006 - 08:19 PM
i had the same problem. djet kit and used the 165 main it came with. dropped down to the 160 main and problem solved. keep the djet needle and settings the kit recomends, just try the 160. oh, drill the slide.
Honda XR650L 2017
  • 0 reviews
  • Hot  60 replies
  • 22 replies
Honda XR650L 2016
  • 0 reviews
  • Hot  35 replies
