"How-To" sand down valve shims
14 replies to this topic
  • specialk6r
Posted May 11, 2006 - 08:59 PM
Well I've heard of at least a couple folks sanding down valve shims to get the clearances perfect, so my buddy and I did it last night on his sportbike (Kawasaki ZX-9R if anyone cares.)
The bike has the same shim-under bucket design of our bikes but uses 7.48 shims rather than our big 9's. We just set a sheet of wet 400-grit on a flat piece of metal and sanded away. They are really hard and it takes about 5 minutes of intense sanding to get them down a few hundredths. This allowed us to get the clearances right in the middle of the range, which the factory .05-incriment shims prevented. We've only got a couple rides on the bike, but so far it is working flawlessly.
I'm going to save myself some money and do the same on my WR this weekend, since both my exhaust valves are .01 tight. Does anyone see any problems with this? I'd love to hear from anyone else who's done it.
  • JSanfilippo
Posted May 11, 2006 - 09:02 PM
The only concern with that is the possibilty of the shim not being uniform thickness and screwing up the accuracy of the measurements. Its a good alternative for someone who's shop doesn't have a shim exchange program
  • specialk6r
Posted May 11, 2006 - 09:18 PM
Yes, the uniformity of the shim was my only concern, since after reinstalling the shim we checked the clearances again.
Does anyone know how perfect they need to be? Our digital caliper said the were the same at all edges. My technique was to sand side to side one way for 10 seconds, rotate the shim 90 degrees and repeat until it was to the right thickness. This seemed to have kept it fairly even.
  • JSanfilippo
Posted May 11, 2006 - 09:31 PM
They need to be pretty much dead on. I'm pretty sure when the engineers designed these motors, the valve clearances were spec'ed out with the requirements that the shims be perfectly uniform across the top and bottom faces.
  • AUS_WR450
Posted May 11, 2006 - 10:40 PM
FYI, The shims for the Honda CRF450 are identical to the Yamaha ones, and here in Australia, they are half the price as well. Also, which was more important to me, was that the Honda shims can be bought in increments of .025 mm, which allows you a bit more flexibility, when trying to get the clearances matched or in the middle of the range.
  • odonnks
Posted May 12, 2006 - 02:00 AM
Another alternative would be a diamond hone like you would use to sharpen a good knife. When new they are very flat.
  • GCannon
Posted May 12, 2006 - 09:10 AM
Aus has it right the Honda shims are the ticket. set them up to the loose side of the tolerance you will get the same performance and your motor will last longer.
Posted May 12, 2006 - 10:08 AM
The only right way to change thickness is to surface grind them, and allway put the resurface side down.
  • Numskull
Posted May 12, 2006 - 04:20 PM
I wouldnt recommend grinding them as that would create heat and cause the metal to loose its temper.
What you did sounds perfect. Although I have heard that a fiquer 8 pattern keeps things flatter, but who knows. You mic'ed them and they are uniform and now the right tolerance. Good job, and thanks for the tip :ride:
  • txthumper
Posted May 12, 2006 - 05:28 PM
i have done it using a figure 8...it works if your in a jam, but its hard on the finger tips!!
  • specialk6r
Posted May 12, 2006 - 07:24 PM
I actually did one of the shims with a knife sharpening stone, which I will use on my own since I only need to grind 2 shims. The stone seems like a safer way to get them flat but it takes a long time when your doing 16 of them like we we're on the big inline four. I think when I do mine I'll do the figure 8 then rotate 90 degrees every 20 seconds to ensure they're flat.
As far as this being too labor intensive, it takes about 8 minutes per shim if they're only a few hundredths tight. I'll have it done in less time than it would take me to run into town to buy new shims, not to mention saving a few bucks.
Does anyone who's done this have a long term report?
  • AUS_WR450
Posted May 12, 2006 - 08:20 PM
This is an excerpt from ARin's post regarding a little problem he had (it is definitely worth a read). He recommends NOT to grind the shims.
ARin's Disaster
there was ALSO A problem with the grinding of the shims. When taking apart the motor, we realized that the valve shim buckets had aggresive swirl marks in them. This leads me to believe that the grinding of the shims that we did, is not exactly flat...causing the buckets to sit off kilter, and spin when the cam lobes contact them. All the shims were replaced with brand new Hotcam brand shims. I purchased the whole shim kit for around 60.
  • Bamster
Posted May 13, 2006 - 06:15 AM
Why bother to save 4 dollars a shim.
  • ARin
Posted May 14, 2006 - 01:22 PM
My friend and i had THOUGHT we had achieved a good result, but checking the work a few weeks after, showed HEAVY swirl marks on the buckets! This means that the shimmed bucked was NOT sitting flush, and the pressure of the rotating cam lobes was causing the buckets to SPIN when the engine was running.
Spend the 60 bucks or so, and buy a hotcams shim kit. Then you never have to worry about not having the right shim when you need it.
  • specialk6r
Posted May 15, 2006 - 07:07 PM
Good info fellas. I don't think I'll do it on my own bike, even though I'd be convenient. And for anyone saying, "but they're only five bucks a piece, why bother?" the nearest dealership (Great Escapes Motorsports) is over half an hour away and they are the biggest bunch of POS/waste of life idiots I've ever met. I suppose I'll order up a $35 Hotcams refill, since I'll never use most of the sizes included in the $60 kit.
