gytr clutch cover
4 replies to this topic
  • jwcrf05
Posted May 10, 2006 - 09:25 PM
anybody use one if these? i am just wondering if the finish holds up better than stock.
Posted May 11, 2006 - 07:36 AM
The OEM cover is painted, The GYT-R is anodized (I think), and the raised letters will help keep your boots off the black surface. Better probably, but it will still get scuffed up, I would think.
The main reason these exist is to address the vulnerability of the stock magnesium cover to having a footpeg shoved through it in a pile up. They're heavier and stronger.
  • Ga426owner
Posted May 11, 2006 - 08:14 AM
In combo with the GYTR hub, pp, and basket the GYTR cover is designed to send oil back through the passages similar to the complete hinson. I am considering adding one to my full hinson internal set up hub,pp,basket....or the hinson cover.
Greyracer do you see benefit to the hinson cover or the GYTR for either full GYTR or hinson clutches?
Posted May 11, 2006 - 08:37 AM
Theoretically, yes, but I'm not certain how much oil actually flies around the pressure plate on a running YZF, being a dry sump and all. You already know that oil is pumped through the mainshaft and into the clutch boss, so maybe the cover redirects some of that back to the clutch. It can't hurt in any case, and they do look way cool.
  • SureBlue
Posted May 11, 2006 - 11:46 AM
When I asked about the necessity of Hinson cover, this is what they replied:
"The clutch cover is not mandatory. It has the same coating as the rest of the parts that we sell. It is made out of aluminum so it does help dissipate heat, the other thing is it doesn't wear like your stock cover so it stays looking nicer. Other than that their is no real advantage".
Since the GYTR cover is made by Hinson, I would guess the above applies for it too.
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
  • 9 replies
Need help by Goforaride
  • Hot  68 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • Hot  33 replies
