Downshifting at a stoplight
7 replies to this topic
  • Jawmail
Posted May 10, 2006 - 04:36 AM
Why is it when I stop completely and then try to downshift to first it doesn't go easily. The lever moves but no downshifts occur. I have to tap the lever down like 10 times. If I'm moving then it downshifts normally with a clunk. Any ideas.
  • gnarly sprockets
Posted May 10, 2006 - 04:38 AM
It's normal. Get your shifting done before you are stopped.
  • HappyCurmudgeon
Posted May 10, 2006 - 05:06 AM
Mine does the same thing. :crazy:
Once I am stopped, I let the clutch out slightly, just enough to start to engage, then shift down into 1st and it seems to go in fine.
I am never done shifting into 1st at stop signs, only get as low as second, much to large of a "gap" between 1st & 2nd gear for me to use it as a braking downshift effectively.
I'd chirp the wheel going into 1st if i tried.
  • Supplicate
Posted May 10, 2006 - 05:50 AM
clutch control :crazy:
  • sorenlaf
Posted May 10, 2006 - 07:05 AM
Why is it your fault when your woman buys pants that make her ass look fat?
Same answer: "that's just the way it is..."
Motorcycle use a constant mesh transmission. Shifting is acomplished by engaging and disengaging "dogs" in the transmission; no gears actually engage or disengage.
W/o getting into even more details, the dog engagment works best when both primary (engine) and secondary (wheel) transmission shafts are turning.
--Soren
  • Phuzzy McPhuzzface
Posted May 10, 2006 - 08:35 AM
The pants don't make her ass look fat, her overeating makes her ass look fat.
:crazy:
  • HappyCurmudgeon
Posted May 10, 2006 - 10:11 AM
:crazy:
:ride: :ride:
  • Muddin
Posted May 10, 2006 - 11:19 AM
:crazy: :ride: Downshift a little faster and make her squeal like a pig :ride: :lol:
  • 22 replies
  • Hot  60 replies
  • 3 replies
  • 9 replies
